Sure you need a network connection to the server, how else should you log in? But you do not need a internet connection for login.
Wifi is os dependent so there is no general solution to this. It would be possible to add some plugin for specific os/server combinations to do that. But I think best solution would be a independent tool that offers computer as access point and then from there you would select a network. That would not depend on the server at all. After wifi is working you access the server as supposed.
