Install error on Ubuntu 14.04LTS 64 bit
I get the following error message when trying to install on a new Ubuntu machine.
error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
I thought maybe the library wasnt installed so I ran: sudo apt-get install libstdc++6 but it showed that it was up to date. I'm not very knowledgeable about Linux so maybe its a simple issue I'm doing wrong. Any help would be much appreciated.
Here's the full install log:
repetier@repetier-desktop:~/Downloads$ sudo dpkg -i Repetier-Server-0.75.0-Linux.deb
(Reading database ... 199494 files and directories currently installed.)
Preparing to unpack Repetier-Server-0.75.0-Linux.deb ...
Uninstall Repetier-Server
* Stopping Repetier-Server rsd [ OK ]
Unpacking repetier-server (0.75.0) over (0.75.0) ...
Setting up repetier-server (0.75.0) ...
Install Repetier-Server
You may see warnings about groups. These can be ignored.
The user `repetierserver' is already a member of `tty'.
adduser: The group `intserial' does not exist.
adduser: The group `ugpio' does not exist.
* Starting Repetier-Server rsd /usr/local/Repetier-Server/bin/RepetierServer: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
[fail]
dpkg: error processing package repetier-server (--install):
subprocess installed post-installation script returned error exit status 127
Processing triggers for ureadahead (0.100.0-16) ...
ureadahead will be reprofiled on next reboot
Errors were encountered while processing:
repetier-server
[fail]
repetier-server
even though libstdc++.so.6 was installed. After doing a bit of
searching I found that installing the 32bit version fixed it. So in case
anyone else has this issue here's what I had to do to fix it
sudo apt-get install lib32stdc++6
" intel32: libc 2.19 like used in Ubuntu 14.04LTS
amd64: libc 2.13 like used in Debian Wheezy "
I'm not much of a Linux user I just knew I had Ubuntu 14.04LTS so I went with that. Would the amd64 been a better choice?
