Integration with PrusaSlicer 2.9.3 (flatpak)
RepetierHost 2.3.2 successfully works with PrusaSlicer 2.6.1 which is distributed as a set of files to be unpacked in some directory.
But PrusaSlicer 2.9.3 is only distributed as flatpak. This flatpak app may be run with flatpak run com.prusa3d.PrusaSlicer but RepetierHost requires a path to binary when configuring external slicer. I've tried to create a shell script with this to have this executable:
#!/bin/bash
Configured executor path as /home/user/.var/app/com.prusa3d.PrusaSlicer/config/PrusaSlicer/ and pointed to the above script as PrusaSlicer executable (+x permission set). I'm able to see configurations in drop-down, able to run the slicer for configuration with "Configuration" button in RepetierHost but can't run slicing, getting the following in log:
18:58:18.967 : PrusaSlicer command:/home/user/3D/prusa_flatpak.sh --load "slic3r_settings.ini" --dont-arrange --export-gcode --output "composition.gcode" "composition.amf"
18:58:18.974 : Preferred name from Cube_20x20x20mm to Cube_20x20x20mm
18:58:19.170 : <PrusaSlicer> --------------------------------------------------------------------------
18:58:19.171 : <PrusaSlicer> Message: 18:58:19: Starting PrusaSlicer flatpak with entrypoint script
18:58:19.171 : <PrusaSlicer> --------------------------------------------------------------------------
Running the command manually gives No such file: slic3r_settings.ini but I suggest RepetierHost generates some temporary slic3r_settings.ini for that and don't know how to get the sample for further testing.
So does RepetierHost support PrusaSlicer 2.9.3? How to set these two to work together?
  • By accident found the sample files from previous run of slicer through RepetierHost.
    Tried to manually run the script described above /home/user/3D/prusa_flatpak.sh --load ~/.local/share/RepetierHost/slic3r_settings.ini --dont-arrange --export-gcode --output composition.gcode ~/.local/share/RepetierHost/composition.amf and... successfully got the resulting .gcode file. So the question is now how to make it work with a click of a button in RepetierHost.
