Home issues
So, when I make a script like this:
G28
G0 Z0 Y90 X0 F3500
and then I use it, my printer goes to home, but when it does the move command at the end the z axis still shows the height of home. As in when I home z axis shows something like 650mm, then when I use that script, it still says 650mm on the z axis even though it has moved down to the bed? Anyone having the same issue?
