Repetier on Raspberry PI problem
Hi! I'm using repetier Server on Raspberry PI B. I installed armel version. After a few minutes, the printer stops. If I change the baudrate to 115200 It works well. How can I work with higher baudrates?
  • Not that it would give you much more speed (most slowdown comes from usb latency), but you have to change baudrate in printer firmware AND server or it will not work.
