BFB G-Code style in slic3r
I own a BFB 3DTouch printer. The software which was delivered
with the machine (Axon) is no longer supported, so I want to use
Repetier-Host in the future. The firmware of the machine (5.4.2) uses a
quite uncommon way for extrusion control. Instead of the E axis, I need
to preset the speed for the extruder (M108 Sxxx for extruder 1, M208
Sxxx for extruder 2, M308 Sxxx or extruder 3). M101 starts extruding for
extruder 1, M201 for extruder 2 and M301 for extruder 3. M103 turns all
extruders off.
I could proably achieve this with Skeinforge, but
this is extremely complicated to configure and slicing speed with
Skeinforge is rather slow.
Are there any plans to support this BFB G-Code style in future releases of slic3r?
Thank you or letting me know.
br
Thomas
extruders off.
br
Thomas
Thank you for the quick answer !
I already tried cura engine and I really like it's speed. The G-Code is also very close to what I need for my BFB printer. The only thing I missed with cura is the missing preview when in BFB G-Code mode.
If you could add this in the future, that would be great !
Regarding the extrusion amount: I made some tests with Axon and found out, that extruder speed and feedrate depend on layer thickness and material. Here are some examples:
PLA 0.125mm --> M108 S120.0 - for the first layer, M108 S80.0 for the rest. Feedrate always F960.0
PLA 0.25: M108 S300.0 - first layer, F200.0 for the rest. Feedrate F960.0
PLA 0.5: M108 S675.0 - first layer, F450.0 for the rest. Feedrate 960.0
ABS 0.125 same as PLA 0.125
ABS 0.25 same as PLA 0.25
ABS 0.5 M108 S600.0 - first layer, M108 S400.0 for the rest. Feedrate always 960.0
Communication with the printer:
The printer does not have any direct communication with the host. G-Code files need to be copied on USB sticks and are printed directly from there. I have set it up as virtual connection in Repetier-Host, that works fine.
Please let me know I you need any further details or sample files.
Thank you for your support.
br
Thomas
