G29, G30, G32, S0, S1, S2, measure heights... What a mess! ^^
Hello I'm new on this forum and I have some problem with my autoleveling ( I've got a kossel mini with mks mini v1.1 and repetier firmware)
I've read lot of forum on that and... It's a mess ^^
So, once and for all... What's the difference between G29, G30, G32, S0, S1, S2, what's going on when I click on "measure heights" in the bed map height tool?
Because for me, each command does a different thing and there is any correction done at all.
How do you store the matrix correction on your eeprom? (I know G32 S2, ok... but for me it doesn't work
I guess you'll want some details
Thanks !
Thanks !
Thank you
very much !
But when I Connect my printer, I send a homing and a G33 or G33 S2, I’ve got
that in the logs
15:42:50.878 : N18 G28 *10
15:42:50.881 : Info:Autoleveling disabled
15:42:51.487 : SelectExtruder:0
15:42:51.496 : X:0.00 Y:0.00 Z:250.000 E:0.0000
15:42:51.496 : Info:Autoleveling enabled
15:42:56.009 : N24 G33 *15
15:42:56.014 : Unknown command:N24 G33
After, I send a G32 S2
15:45:37.132 : N173 G32 S2 *124
15:45:41.909 : Info:Autoleveling disabled // (the hotend goes down and up and
do a new homing at this moment… I don’t know why. After it goes down and do the
probing)
15:45:47.050 : SelectExtruder:0
15:45:47.058 : X:0.00 Y:0.00 Z:250.000 E:0.0000
15:45:53.099 : Z-probe:5.53 X:60.00 Y:-70.00
15:45:54.057 : Z-probe:5.55 X:60.00 Y:-46.66
15:45:55.010 : Z-probe:5.51 X:60.00 Y:-23.33
15:45:55.967 : Z-probe:5.50 X:60.00 Y:0.00
15:45:56.920 : Z-probe:5.57 X:60.00 Y:23.
15:45:58.868 : Z-probe:5.72 X:60.00 Y:70.00
15:46:00.724 : Z-probe:5.45 X:40.00 Y:-70.00
15:46:01.665 : Z-probe:5.45 X:40.00 Y:-46.66
15:46:02.606 : Z-probe:5.43 X:40.00 Y:-23.33
15:46:03.555 : Z-probe:5.46 X:40.00 Y:0.00
15:46:04.501 : Z-probe:5.54 X:40.00 Y:23.33
15:46:05.463 : Z-probe:5.63 X:40.00 Y:46.66
15:46:06.444 : Z-probe:5.77 X:40.00 Y:70.00
15:46:08.306 : Z-probe:5.48 X:20.00 Y:-70.00
15:46:09.251 : Z-probe:5.44 X:20.00 Y:-46.66
15:46:10.195 : Z-probe:5.52 X:20.00 Y:-23.33
15:46:11.149 : Z-probe:5.48 X:20.00 Y:0.00
15:46:12.102 : Z-probe:5.54 X:20.00 Y:23.33
15:46:13.059 : Z-probe:5.63 X:20.00 Y:46.66
15:46:14.045 : Z-probe:5.83 X:20.00 Y:70.00
15:46:15.915 : Z-probe:5.57 X:0.00 Y:-70.00
15:46:16.872 : Z-probe:5.53 X:0.00 Y:-46.66
15:46:17.821 : Z-probe:5.51 X:0.00 Y:-23.33
15:46:18.786 : Z-probe:5.61 X:0.00 Y:0.00
15:46:19.748 : Z-probe:5.59 X:0.00 Y:23.33
15:46:20.709 : Z-probe:5.66 X:0.00 Y:46.66
15:46:21.691 : Z-probe:5.79 X:0.00 Y:70.00
15:46:23.586 : Z-probe:5.75 X:-20.00 Y:-70.00
15:46:24.560 : Z-probe:5.67 X:-20.00 Y:-46.66
15:46:25.530 : Z-probe:5.62 X:-20.00 Y:-23.33
15:46:26.500 : Z-probe:5.62 X:-20.00 Y:0.00
15:46:27.469 : Z-probe:5.66 X:-20.00 Y:23.33
15:46:28.439 : Z-probe:5.72 X:-20.00 Y:46.66
15:46:29.433 : Z-probe:5.83 X:-20.00 Y:70.00
15:46:31.352 : Z-probe:5.91 X:-40.00 Y:-70.00
15:46:32.351 : Z-probe:5.82 X:-40.00 Y:-46.66
15:46:33.337 : Z-probe:5.75 X:-40.00 Y:-23.33
15:46:34.323 : Z-probe:5.74 X:-40.00 Y:0.00
15:46:35.313 : Z-probe:5.73 X:-40.00 Y:23.33
15:46:36.295 : Z-probe:5.78 X:-40.00 Y:46.66
15:46:37.294 : Z-probe:5.88 X:-40.00 Y:70.00
15:46:39.229 : Z-probe:6.16 X:-60.00 Y:-70.00
15:46:40.258 : Z-probe:6.00 X:-60.00 Y:-46.66
15:46:41.269 : Z-probe:5.92 X:-60.00 Y:-23.33
15:46:42.280 : Z-probe:5.86 X:-60.00 Y:0.00
15:46:43.270 : Z-probe:5.83 X:-60.00 Y:23.33
15:46:44.269 : Z-probe:5.87 X:-60.00 Y:46.66
15:46:45.267 : Z-probe:5.86 X:-60.00 Y:70.00
15:46:45.664 : plane: a = -0.0031 b = 0.0008 c = 5.6722
15:46:45.672 : Transformation matrix: 0.999995 0.000002 0.003077 0.000000
1.000000 -0.000807 -0.003077 0.000807 0.999995
15:46:45.672 : CurrentZ:5.91 atZ:10.00
15:46:45.676 : Z after rotation:10.24
15:46:45.676 : Printer height:245.67
15:46:45.680 : Info:Autoleveling enabled
15:46:46.480 : X:-59.98 Y:70.00 Z:6.151 E:0.0000
15:46:46.480 : Info:Autoleveling disabled
15:46:53.565 : SelectExtruder:0
15:46:53.570 : X:0.00 Y:0.00 Z:245.670 E:0.0000
15:46:53.570 : Info:Autoleveling enabled
In my config.h
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PIN ORIG_Y_MIN_PIN
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 20
#define Z_PROBE_XY_SPEED 80
#define Z_PROBE_SWITCHING_DISTANCE 3
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -69.28
#define Z_PROBE_Y1 -40
#define Z_PROBE_X2 69.28
#define Z_PROBE_Y2 -40
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 80
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 7
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Do you know why G33 doesn't work?
Sorry for this "stupid" question
in configuration.h to get G33, but you have said you do not have it or you are using an older repetier-firmware and not the latest version.
Thanks... it's better ^^
But now I have an oder issue. If I send G29, G32 or G33 the hotend goes out of bed and I have to quickly stop it before dammage.
My Z_PROBE_X and Y seems good, no?
Where is there something who tell it to go so far out of bed ??
I guess it's stupide but... I can't find !
#define Z_PROBE_SPEED 1
#define Z_PROBE_XY_SPEED 60
#define Z_PROBE_SWITCHING_DISTANCE 0
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT -1
#define Z_PROBE_X1 -70
#define Z_PROBE_Y1 -70
#define Z_PROBE_X2 -70
#define Z_PROBE_Y2 +70
#define Z_PROBE_X3 +70
#define Z_PROBE_Y3 -70
#define BED_LEVELING_GRID_SIZE 4
#define BED_LEVELING_REPETITIONS 1
The eeprom and the firmeware are the same, the z probe offset is 0 and I always do a homing before try z probing.
My bed's radius is 110 mm.
And, what's exactly that?
#define UI_BED_COATING 1 // he has 0
#define Z_PROBE_BED_DISTANCE 10 //he has 5
#define Z_PROBE_SPEED 2 //he has 1
#define Z_PROBE_XY_SPEED 150 //he has 60
#define Z_PROBE_SWITCHING_DISTANCE 1 //he has 0
#define Z_PROBE_REPETITIONS 1 //he has 2
#define Z_PROBE_HEIGHT 40 //he has -1
#define BED_LEVELING_METHOD 0 //he has 1
#define BED_LEVELING_GRID_SIZE 5 //he has 4
#define BED_LEVELING_REPETITIONS 5 //he has 1
#define FEATURE_AXISCOMP 0 //he has 1
This is firmware repetier 0.92 (i guess)
is your nozzle the z probe because you did not give it an offset!
A#part from this valus seem good for a start also i doubt the z probe offset is correct.
Diameter of my glass is 200mm (radius is 100mm).
