SSH Access Denied
Somehow I am unable to connect anymore via SSH to the Raspberry pi's that run Repetier Server. This is the case on 6 printers and I am 100% sure the login credentials are correct. Did something change recently regarding this?
Is ssh still running? In server -> global settings->terminal you can login as well without requiring ssh but with same password. You can check there if sshd is running
ps aux | grep sshd
