"Load Config Bundle..." option on Mac?
Hello all!
I recently got a FolgerTech 2020 i3 Prusa. I'm going through the configuration instructions, and I'm having a problem with Step 6 Part 2. The instructions are based on Windows, and they don't cover any of the differences with Mac.
Step 6 Part 2 says to click "File > Load Config Bundle..." I noticed that there are 2 menu options: "Load Config..." and "Load Config Bundle..." I'm not sure how these two options are different.
On the version of slic3r that comes with Repetier-Host Mac, the correct option is not in the menu, as you can see in this screenshot:
I tried adding the provided config bundle via the "Load Config..." option. That crashes the program and logs the error "<Slic3r> Unreadable configuration file (invalid data at line 3)." Line 3 is the beginning of the content.
Is there an alternative to "Load Config Bundle..." that I can use for Repeiter-Host Mac?
Many thanks!
