[0.70.1 linux] Timelapse fps stuck on 25fps
I am running 0.70.1 on a RaspPi B+. I have MPEG+JPG urls set OK and can create timelapse videos with ffmpeg. In the printer webcam tab have set the timelapse settings to 1 shot per layer and 15fps and APPLY. But when I go to some other section and come back to the printer webcam tab the menu is 25fps. The timelapse videos are too fast - I want to slow them down a bit, but the setting does not seem to allow changes.
EG: If I try 25fps then a video is for 245 layers is 11s. But if I select 10fps and recreate the video then the length is again 11s long - it should be about 25s long.
