Rescue didn't work, 23 hour print failed at 20 hours, with no rescue
I'm not sure if this is a bug or it's just a failure that cannot be recovered.  My Prusa MK3S failed around 20 hours into a 23 hour print with a print bed runoff failure and said to restart the printer.  Normally with any kind of failure or power outage the Prusa software returns with a Rescue button to restart but this time it was not there.  I can't find anything in the logs to tell me what height or position or layer it failed on and I can't find any help on how to manually rescue.  Am I lost and should I just restart the print?
Thanks!
  • Prusa rescue does not work when printing from server since it is not printing from sd card. Only exception is if it detects loosing steps it will correct that automatically.
    Server has a own rescue solution also it might log some moves, but when enabled it gives you an idea on where it happened so you can eventually continue if no homing/bed leveling is required which is impossible with objects on bed. This works best with z max homing printers.
    You can also check print history which shows where a print was aborted. That can allow to to make a reduced g-code so you can continue if you can restore end conditions (temperature, z position home xy)
