Double/Quadstepping Setup
Hi All,
is there someone who can help me with setup of double/quadstepping?
Firmware 092.6 (downloaded January 6th)
Hardware Mega2560 , Ramps 1.4 DRV8825 drivers. Motors 0.9° Nema 17 for direct Drive Extruders (2) .
Motors 1.8°Nema 23 (2A) for x , y Nema 17 (92oz) 1,8° for z Axis.
threaded Rods TR 16*4 for all axis.
Microstepping for x and y 1/4 (200 steps/mm) , 1/32 for z(1600 steps/mm).
I can Drive x and y up to 85 mm/s each but when i drive both i get stall at around 45 mm/s Feedrate.
basically for printing it´s enough but for travelling it´s too low .
i tried to change :
#define DOUBLE_STEP_DELAY in a Range from 0 to 10 , (Optimum seems around 3 )
and
#define STEPPER_HIGH_DELAY in a Range from 1 to 4
but i seems Quadstepping isn´t working for me...
is anybody out there who solved similar problem ?
Thank´s in Advance
RAyWB
i tried to change :
and
Thank´s in Advance
RAyWB
i can go up to 115 mm/s now when i drive single axis and around 95 when drive both axis.
i had to disable quadstepping because of earlier stall .
so i think my problem moved to the steppers now , they have to spin with more than 1400 rpm...
i read about usual rpms around 600 to 1000 maximum higher rpms is CNC Servomotor league......
Thanks for your support
RAyWB
