TCP/IP Issues
Trying repetier for the first time to see if it works for what we need in our Farm, but I keep hitting a brick wall with every machine I try setting up, be it Prusa, Elegoo, whatever.
Taking the Prusa XL as an example, i'm setting:
But I always end up getting the error: "Could not start connection with set TCP/IP. Please select the right one"
I know for a fact that the IP and Password are correct as I've tested them via both Prusa Connect and Prusa Link.
Plus, the same error occurs when trying to set up a Neptune 4 Plus, for example, which asks for less info as it's running Klipper.
Any help would be appreciated.
CJ
- Firmware: Marlin
- Connection Method: TCP/IP Connection
- IP: 192.16.x.xx (parsed for security purposes)
- Port: 80 (tried 23, 5000, 8080 as well)
- Password: PrusaLink API Key (parsed for security purposes)
CJ
Such connectors are on it"s way starting with bambu connector and then moonraker(klipper) and then probably PrusaConnect. This requires a deep modification of server, because not evertything is possible over such solutions. It all depends on what the api of the printer allows to do and returns as informations. But I assume once first connector works further connectors are much faster to implement.
