Thermistor work only in manual controll
if i start print, first heatup bed, second hotend starts heat up, but every time temperature stop in some celsius and do not print. But after emergency stop is temperature ok and show celsius what i set.
I use lubuntu and newest repetier host.
Do i anything wrong?
Známka
Ivica
  • Does the firmware finish the heat up command or was it waiting for target temperature and that never reached? Then you have to fix settings in firmware.
  • The temperature rises to 230, and while it is printing. Then suddenly stops, and print temperature hotend in repetieru unresponsive. Gets stuck.
  • What firmware are you using? Marlin seems not to send temperatures while running M109/M190 commands. These wait for target temperatures which might luck like stuck, but in reality only is waiting for temperatures.
  • Im using repetier FW. I tried 91 and 92.
  • If you log to file, what does it say? Any M105 requests and answers in log? In printer settings you can disable M105 polling that would also result in no temp. updates after M109/M190.
  • Kde najdu log soubor? Vypnu M105 s dotazem, ale stil špatný
  • Where i find log file? I turn off M105 ask, but still doesnt work.
  • Log is in work directory if you have enabled it in preferences->general
  • Hello, here is lot of lines before stops print.
     22:30:37.678 : N12161 G1 X87.842 Y110.24 E20.80822 *114
    > 22:30:37.715 : ok 12156
    < 22:30:37.715 : N12162 G1 X87.732 Y109.587 E20.83594 *78
    > 22:30:37.753 : ok 12157
    < 22:30:37.753 : N12163 G1 X87.695 Y108.998 E20.86066 *77
    > 22:30:37.776 : ok 12158
    < 22:30:37.776 : N12164 G1 X87.711 Y108.584 E20.87798 *65
    > 22:30:37.801 : ok 12159
    < 22:30:37.801 : N12165 G1 X87.76 Y108.171 E20.8954 *65
    > 22:30:37.834 : ok 12160
    < 22:30:37.834 : N12166 G1 X87.842 Y107.763 E20.91282 *71
    > 22:30:37.857 : ok 12161
    < 22:30:37.857 : N12167 G1 X87.955 Y107.362 E20.93024 *72
    > 22:30:37.874 : ok 12162
    < 22:30:37.875 : N12168 G1 X88.099 Y106.972 E20.94766 *77
    > 22:30:37.903 : ok 12163
    < 22:30:37.903 : N12169 G1 X88.273 Y106.594 E20.96508 *70
    > 22:30:37.928 : ok 12164
    < 22:30:37.928 : N12170 G1 X88.476 Y106.231 E20.9825 *113
    > 22:30:37.958 : ok 12165
    < 22:30:37.958 : N12171 G1 X88.707 Y105.885 E20.99992 *71
    > 22:30:37.981 : ok 12166
    < 22:30:37.981 : N12172 G1 X88.965 Y105.558 E21.01734 *65
    > 22:30:38.008 : ok 12167
    < 22:30:38.008 : N12173 G1 X89.247 Y105.252 E21.03476 *64
    > 22:30:38.030 : ok 12168
    < 22:30:38.030 : N12174 G1 X89.551 Y104.972 E21.05206 *72
    > 22:30:38.055 : ok 12169
    < 22:30:38.055 : N12175 G1 X90.083 Y104.577 E21.07978 *66
    > 22:30:38.079 : ok 12170
    < 22:30:38.079 : N12176 G1 X90.591 Y104.277 E21.1045 *113
    > 22:30:38.219 : ok 12171
    < 22:30:38.219 : N12177 G1 X90.967 Y104.104 E21.12182 *74
    > 22:30:38.223 : ok 12172
    < 22:30:38.223 : N12178 G1 X91.357 Y103.96 E21.13924 *117
    > 22:30:38.230 : ok 12173
    < 22:30:38.230 : N12179 G1 X91.758 Y103.846 E21.15668 *75
    > 22:30:38.231 : ok 12174
    > 22:30:38.231 : ok 12175
    < 22:30:38.231 : N12180 G1 X92.094 Y103.778 E21.17103 *67
    < 22:30:38.231 : N12181 G1 X92.579 Y103.717 E21.1915 *117
    > 22:30:38.255 : ok 12176
    < 22:30:38.256 : N12182 G1 X93.065 Y103.701 E21.21184 *74
    > 22:30:38.281 : ok 12177
    < 22:30:38.281 : N12183 G1 X93.457 Y103.721 E21.22825 *77
    > 22:30:38.309 : ok 12178
    < 22:30:38.309 : N12184 G1 X94.151 Y103.829 E21.25769 F900 *22
    > 22:30:38.333 : ok 12179
    < 22:30:38.333 : N12185 G1 X94.758 Y104.006 E21.28415 *64
    > 22:30:38.370 : ok 12180
    < 22:30:38.370 : N12186 G1 X94.877 Y104.422 F7800 *88
    > 22:30:38.407 : ok 12181
    < 22:30:38.407 : N12187 G1 X94.19 Y104.948 F7800 *104
    > 22:30:38.432 : ok 12182
    < 22:30:38.432 : N12188 G1 X97.038 Y107.796 E21.50345 F1200 *42
    > 22:30:38.460 : ok 12183
    < 22:30:38.460 : N12189 G1 X97.217 Y108.593 E21.5479 *113
    > 22:30:38.486 : ok 12184
    < 22:30:38.486 : N12190 G1 X93.407 Y104.782 E21.84128 *76
    > 22:30:38.510 : ok 12185
    < 22:30:38.510 : N12191 G1 X92.76 Y104.752 E21.87658 *112
    > 22:30:38.534 : ok 12186
    < 22:30:38.534 : N12192 G1 X97.245 Y109.237 E22.22191 *65
    > 22:30:38.559 : ok 12187
    < 22:30:38.559 : N12193 G1 X97.181 Y109.791 E22.25225 *73
    > 22:30:38.584 : ok 12188
    < 22:30:38.585 : N12194 G1 X95.593 Y108.203 E22.37448 *74
    > 22:30:38.608 : ok 12189
    < 22:30:38.608 : N12195 G1 X95.692 Y108.919 E22.4138 *123
    > 22:30:38.636 : ok 12190
    < 22:30:38.637 : N12196 G1 X97.066 Y110.293 E22.5196 *114
    > 22:30:38.661 : ok 12191
    < 22:30:38.661 : N12197 G1 X96.904 Y110.749 E22.54593 *72
    > 22:30:38.687 : ok 12192
    < 22:30:38.687 : N12198 G1 X95.628 Y109.472 E22.64421 *77
    > 22:30:38.726 : ok 12193
    < 22:30:38.727 : N12199 G1 X95.484 Y109.946 E22.67116 *64
    > 22:30:38.763 : ok 12194
    < 22:30:38.763 : N12200 G1 X96.692 Y111.154 E22.76417 *67
    > 22:30:38.788 : ok 12195
    < 22:30:38.788 : N12201 G1 X96.452 Y111.531 E22.78851 *75
    > 22:30:38.812 : ok 12196
    < 22:30:38.813 : N12202 G1 X95.277 Y110.356 E22.87898 *73
    > 22:30:38.839 : ok 12197
    < 22:30:38.839 : N12203 G1 X95.019 Y110.715 E22.90306 *75
    > 22:30:38.858 : ok 12198
    < 22:30:38.858 : N12204 G1 X96.17 Y111.867 E22.99172 *114
    > 22:30:38.887 : ok 12199
    < 22:30:38.887 : N12205 G1 X95.862 Y112.175 E23.01548 *78
    > 22:30:39.022 : ok 12200
    < 22:30:39.023 : N12206 G1 X94.71 Y111.024 E23.10413 *127
    > 22:30:39.026 : ok 12201
    < 22:30:39.027 : N12207 G1 X94.353 Y111.284 E23.12819 *65
    > 22:30:39.031 : ok 12202
    > 22:30:39.031 : ok 12203
    < 22:30:39.031 : N12208 G1 X95.522 Y112.453 E23.21824 *78
    < 22:30:39.031 : N12209 G1 X95.149 Y112.697 E23.24252 *66
    > 22:30:39.067 : ok 12204
    < 22:30:39.068 : N12210 G1 X93.943 Y111.491 E23.33541 *74
    > 22:30:39.117 : ok 12205
    < 22:30:39.117 : N12211 G1 X93.471 Y111.637 E23.36227 *75
    > 22:30:39.305 : ok 12206
    < 22:30:39.305 : N12212 G1 X94.743 Y112.909 E23.4602 *126
    > 22:30:39.354 : ok 12207
    < 22:30:39.354 : N12213 G1 X94.29 Y113.073 E23.48643 *124
    > 22:30:39.612 : ok 12208
    < 22:30:39.612 : N12214 G1 X92.908 Y111.691 E23.59284 *64
    > 22:30:39.657 : ok 12209
    < 22:30:39.657 : N12215 G1 X92.205 Y111.605 E23.63144 *76
    > 22:30:39.958 : ok 12210
    < 22:30:39.958 : N12216 G1 X93.786 Y113.186 E23.75321 *72
    > 22:30:40.120 : ok 12211
    > 22:30:40.120 : ok 12212
    < 22:30:40.121 : N12217 G1 X93.231 Y113.249 E23.78361 *73
    < 22:30:40.121 : N12218 G1 X88.745 Y108.763 E24.12901 *74
    > 22:30:40.165 : ok 12213
    < 22:30:40.165 : N12219 G1 X88.802 Y108.202 E24.15969 *76
    > 22:30:40.259 : ok 12214
    < 22:30:40.260 : N12220 G1 X90.393 Y109.793 E24.28219 *66
    > 22:30:40.296 : ok 12215
    < 22:30:40.296 : N12221 G1 X90.306 Y109.089 E24.32084 *78
    > 22:30:40.395 : ok 12216
    < 22:30:40.395 : N12222 G1 X88.921 Y107.704 E24.42749 *70
    > 22:30:40.436 : ok 12217
    < 22:30:40.436 : N12223 G1 X89.086 Y107.252 E24.45368 *68
    > 22:30:40.526 : ok 12218
    < 22:30:40.526 : N12224 G1 X90.36 Y108.526 E24.55175 *116
    > 22:30:40.558 : ok 12219
    < 22:30:40.559 : N12225 G1 X90.5 Y108.048 E24.57885 *76
    > 22:30:40.649 : ok 12220
    < 22:30:40.649 : N12226 G1 X89.293 Y106.841 E24.67173 *70
    > 22:30:40.687 : ok 12221
    < 22:30:40.687 : N12227 G1 X89.533 Y106.464 E24.69607 *75
    > 22:30:40.772 : ok 12222
    < 22:30:40.772 : N12228 G1 X90.708 Y107.639 E24.78648 *70
    > 22:30:40.804 : ok 12223
    < 22:30:40.804 : N12229 G1 X90.968 Y107.281 E24.81054 *69
    > 22:30:40.894 : ok 12224
    < 22:30:40.895 : N12230 G1 X89.82 Y106.133 E24.89895 *126
    > 22:30:40.927 : ok 12225
    < 22:30:40.927 : N12231 G1 X90.128 Y105.825 E24.92271 *65
    > 22:30:41.017 : ok 12226
    < 22:30:41.017 : N12232 G1 X91.277 Y106.973 E25.01115 *65
    > 22:30:41.054 : ok 12227
    < 22:30:41.054 : N12233 G1 X91.635 Y106.714 E25.03522 *79
    > 22:30:41.218 : ok 12228
    < 22:30:41.218 : N12234 G1 X90.468 Y105.547 E25.12514 *65
    > 22:30:41.223 : ok 12229
    < 22:30:41.223 : N12235 G1 X90.841 Y105.303 E25.14942 *72
    > 22:30:41.279 : ok 12230
    < 22:30:41.280 : N12236 G1 X92.048 Y106.509 E25.24233 *73
    > 22:30:41.316 : ok 12231
    < 22:30:41.316 : N12237 G1 X92.523 Y106.368 E25.26935 *78
    > 22:30:41.416 : ok 12232
    < 22:30:41.416 : N12238 G1 X91.247 Y105.091 E25.36764 *74
    > 22:30:41.461 : ok 12233
    < 22:30:41.461 : N12239 G1 X91.701 Y104.928 E25.39392 *68
    > 22:30:41.578 : ok 12234
    < 22:30:41.579 : N12240 G1 X93.082 Y106.309 E25.50021 *75
    > 22:30:41.619 : ok 12235
    < 22:30:41.620 : N12241 G1 X93.793 Y106.403 E25.53927 *76
    > 22:30:41.918 : ok 12236
    < 22:30:41.918 : N12242 M117 ETE 3m 09s *83
    > 22:30:41.958 : ok 12237
    < 22:30:41.958 : N12243 G1 X92.197 Y104.806 E25.66218 *71
    > 22:30:42.080 : ok 12238
    < 22:30:42.080 : N12244 G1 X95.564 Y105.705 F7800 *92
    > 22:30:42.123 : ok 12239
    < 22:30:42.123 : N12245 G1 X96.279 Y106.419 E25.71717 F1200 *47
    > 22:30:42.316 : ok 12240
    < 22:30:42.316 : N12246 G1 E22.21717 F2400 *18
    > 22:30:42.320 : ok 12241
    < 22:30:42.320 : N12247 G92 E0 *101
    > 22:30:42.357 : ok 12242
    < 22:30:42.357 : N12248 G1 X88.777 Y109.412 F7800 *85
    < 22:30:42.357 : N12249 G1 E3.5 F2400 *41
    > 22:30:42.521 : ok 12243
    < 22:30:42.521 : N12250 G1 X92.586 Y113.221 E3.79327 F1200 *26
    > 22:30:42.524 : ok 12244
    > 22:30:42.525 : ok 12245
    > 22:30:42.525 : ok 12246
    < 22:30:42.525 : N12251 G1 X91.801 Y113.053 E3.83697 *115
    < 22:30:42.525 : N12252 G1 X88.942 Y110.194 E4.05709 *120
    < 22:30:42.525 : N12253 G1 X89.718 Y111.588 F7800 *92
    > 22:30:42.611 : ok 12247
    > 22:30:42.647 : ok 12248
    > 22:30:42.647 : ok 12249
    < 22:30:42.648 : N12254 G1 X90.426 Y112.295 E4.11154 F1200 *22
    < 22:30:42.648 : N12255 G1 Z7.2 F7800 *49
    > 22:30:42.734 : ok 12250
    < 22:30:42.734 : N12256 G1 E0.61154 F2400 *38
    < 22:30:42.734 : N12257 G92 E0 *100
    > 22:30:42.766 : ok 12251
    < 22:30:42.766 : N12258 G1 X93.823 Y106.695 F7800 *82
    > 22:30:42.852 : ok 12252
    < 22:30:42.852 : N12259 G1 E3.5 F2400 *40
    > 22:30:42.890 : ok 12253
    < 22:30:42.890 : Tisky vrstvy 24 z 39
    < 22:30:42.890 : N12260 G1 X94.165 Y106.848 E3.51959 F900 *36
    > 22:30:42.979 : ok 12254
    < 22:30:42.979 : N12261 G1 X94.48 Y107.052 E3.53918 *65
    > 22:30:43.116 : ok 12255
    < 22:30:43.116 : N12262 G1 X94.76 Y107.302 E3.55877 *71
    > 22:30:43.118 : ok 12256
    < 22:30:43.119 : N12263 G1 X95.003 Y107.596 E3.57872 *121
    > 22:30:43.139 : ok 12257
    > 22:30:43.240 : ok 12258
    > 22:30:43.240 : ok 12259
    < 22:30:43.240 : N12264 G1 X95.19 Y107.915 E3.59804 *77
    < 22:30:43.240 : N12265 G1 X95.33 Y108.261 E3.61754 *66
    > 22:30:43.278 : ok 12260
    < 22:30:43.278 : N12266 G1 X95.415 Y108.626 E3.63713 *119
    > 22:30:43.372 : ok 12261
    < 22:30:43.373 : N12267 G1 X95.444 Y109 E3.65672 *111
    > 22:30:43.418 : ok 12262
    < 22:30:43.418
  • Looks like the end is missing. You need to close host to finish writing or the log may be incomplete. Interesting is where it stops responding.
  • This is it place where just lag.
  • No it isn't. The log is just not flushed fully to disk! If a date comes there is always a content. Close host to flush log to the end received.
