Connect to server
How do I verify that I am connected, after I hit connect and tab goes green. Don't thing my print files don't get sent. Can not get my first print
  • Being connected to server doe snot mean you can print. Printer must be connected. You can best see this in server frontend if it is green. Once server is configured correctly it will autoconnect as soon as you connect printer, but first you have to add printer, set port and baud rate. In host server tab will show if printer is online, but only in server forntend you can set it up.
