Temperature not rising
So I am trying my first print. I get the gcode into the host and click start. The temperature of the bed and extruder starts to rise. After coupl of minutes, the temperature stops rising. The bed gets stuck around 80 degrees, and the extruder around 30. Anyone knows how to solve this?
  • What does host power out put show? Any messages in log?
    You can limit max. power to heaters in firmware, so if limit is too low you never reach target temperature. There are also max. temperatures set in firmware.
  • Ah and host has also a max temperature you can set.
