Prusa MK4/XL read strain gauge sensor data
We are currently in a research project and would like to read out the strain gauge values of the DMS of a Prusa MK4/XL that is used for nozzle probing and filament stuckage currently.
The display of the the printer can display the values so I am wondering if they could be read out also in the console?
Best regards
Michael
Best regards
Michael
Do you need a special command to get the value or is it included e.g. in temperature report which you can already show in console with ack disabled and temperature filter turned off.
Recv:14:38:27.960: T:25.00/0.00 B:24.27/0.00 C:-30.00/0.00 X0:26.00/36.00 A:36.88/0.00 T0:25.00/0.00 T1:25.00/0.00 T2:6.00/0.00 T3:6.00/0.00 T4:6.00/0.00 T5:6.00/0.00 @:0 B@:0 HBR@:0 @0:0 @1:0 @2:0 @3:0 @4:0 @5:0 B_0_0:24.50/0.00 B_1_0:24.30/0.00 B_2_0:24.10/0.00 B_3_0:24.20/0.00 B_0_1:24.20/0.00 B_1_1:24.30/0.00 B_2_1:24.40/0.00 B_3_1:24.10/0.00 B_0_2:24.30/0.00 B_1_2:24.40/0.00 B_2_2:24.30/0.00 B_3_2:24.10/0.00 B_0_3:24.20/0.00 B_1_3:24.40/0.00 B_2_3:24.30/0.00 B_3_3:24.30/0.00
I tried to home Z and compare those values before/after hitting the bed but I assume the load cell values are not in there.
While printing the live status of the sensor can be read on the MK4/XL LCD via:
Tune --> Info --> Sensor Info --> Loadcell value
https://help.prusa3d.com/article/buddy-firmware-specific-g-code-commands_633112#special-other-commands
but did not find a candidate, so maybe it is not readable externally.
Thank You !
