V 1.6.0 has strange habits !!!
Hello everybody who makes the Repetier software,
I just want to know why the software programmer of Repetier doing bad programming ?
At first I used the Version 0.84 which was working fine. (Just a few bugs in saving the settings and generating G-Code.)
After pressing the "Strat printing" button the printer went to the corner of the heat plate and took down on it and was waiting for themperature of the nossle. After the themp. was reached the extruder extruded a bit and then it moved to the inner of the heat plate and started printing.
Fine so far !!!
In ersion V1.6.0 the Nossle goes to the corner of the heat plate and waits there, then it takes down and waits, and then it moves up, waits and then it moves down again and moves to the inner of the plate to start Printing ! WTF !!!
After printing the firs 2 Layers the printer solwed down and printed a layer with 1mm wide filament ! WTF !!! I didn´t make that setting.
Why is this ????
Why did you change the behave of the printer, even printing it self is different to version 0.84 !! It´s not good this way !!!
Don´t you realize it ! Have you ever worked with the software you are making ???
It was printing verry well on behave of version 0.84 !!!
Why did you change that ? Tell me the reason ! I would like to know what´s going on in the heads of people like you, because i don´t understand such doings ! Does not make sense to me ! You are making new versions and they are worse then bevore !
Well done, maid !
Since Version 0.84 there was no new version that made me and my K8200 Printer happy !
If you want people to pay for software then it needs to be perfect ! But this software is far away from beeing perfect.
Please tell me, why is it not possible for you guys to make the new version better then the old one ??? What is your problem ?
Regards,
Tswoshman
Fine so far !!!
Why is this ????
Well done, maid !
Regards,
Tswoshman
I just try to understand the thing.
But, it can´t be that I have to reed the G-Code to make sure all the settings are set as I want it.
Also, there is always an error that appears.
error: Line number is not last line number+1
also :
Comunication time out - reset send buffer block
What does that mean ??? Isn´t it possible to make the error messages containing a little bit more information than this ?
The printer works anyway !
Next problem I do not understand :
Always on layer 4 the printer slowes down to make a layer with very wide filament. It´s 0.5mm wide and it takes ages to make the layer and it´s infil. I didn´t do this setting and I don´t want it ! WTF ! How can I change this.
I set the first layer on 0.25mm and the others on 0.15mm but layer 4 is made with 0.5mm ?????????
And you want to tell me it´s not programmers fault ???
Why do I not have this problems on version 0.84 ??? (there are other problems ! lol.)
The software would be nice if there would no bug in it !
At least this is how it looks like to me, sorry.
What can I do about it ???? Please help !
