Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Feature Requests
Shutdown button for Raspberry Pi
chaoscrack
December 2015
in
Feature Requests
It would be nice to get buttons to shutdown or reboot the Raspberry Pi. So you do not have to use the SSH or a GUI.
Thank you
Repetier
December 2015
Read manual -> advanced setup on how to do this.
Wapameepto
December 2015
The shutdown and reboot bottons dont work on my Udoo.
If I enter the comand "sudo -s" in a terminal I get a error.
"ubuntu@udoobuntu: / $ sudo -s
sudo: /etc/sudoers.d/repetierserver-RepetierInstaller is mode 0644, should be 0440
sudo: /etc/sudoers.d/repetierserver-shutdown is mode 0644, should be 0440
root@udoobuntu: / $ "
Ich weiß nicht mehr weiter.
Gr
Repetier
December 2015
Looks liek your udoo does not like someone can write the files.
Try
chmod 440 /etc/sudoers.d/repetierserver-RepetierInstaller
chmod 440 /etc/sudoers.d/repetierserver-shutdown
then the WARNINGS should be gone.
But you didn't describe where the problem is. Does the command not appear (server restart is required) or does the command not execute correctly.
Wapameepto
December 2015
Thanks for the fast replay.
The command's not appear. If I press the Button and answer the safty question wrh "yes" nothing happens.
Wapameepto
December 2015
After the two commands all is working. Thanks
Sign In
or
Register
to comment.
