Time Lapse on Repetier-Server 0.70.0 on Raspberry Pi
I've got Repetier-server set up and it's capturing images from mjpeg-streamer. I can step through them in the web interface. However the time lapse videos it lists in the interface are zero byte and won't play. I have ffmpeg installed, but is there a certain plugin I should be using or a setting I need to update to get it to generate proper time lapse videos? Is there a way to test or a log fine I could look at to see what's happening? Any help getting me pointed in the right direction would be appreciated..
Thanks!
I don't know if this will work, but can you create a bash file that takes all the parameters given by repetier server and converts them to what you need and then call your convert program?
Thank you,
Errol
