I understand why you choose to hardcode it in the first place, but are there plans to make this an option via configuration in the future? Maybe with a warning hint that the customizing of the clientId is discouraged?
In the end, as someone who has control over this, its my fault If I use the same clientId twice and cause troubles with my MQTT setup.
Modify the MQTT settings in the Repetier-Server configuration file to modify the MQTT ClientId of a Repetier-Server. Go to Push Service under Config > Preferences. Change the ClientId field to the value you want, making sure it is distinct to prevent conflicts.
Best regards
