sav mk1 extruder fan
i got a funny problem after i downloaded firmware and started from scratch
when i clik the botton in repetier host to turn on the fan nothing happens
but if i do a M42 P16 S255 it turns on
pins section for my board looks like this:
* Teensylu 0.7 pin assingments (ATMEGA90USB)
* Requires the Teensyduino software with Teensy2.0++ selected in arduino IDE!
#if MOTHERBOARD == 8
#define KNOWN_BOARD 1
#define ORIG_X_STEP_PIN 28
#define ORIG_X_DIR_PIN 29
#define ORIG_X_ENABLE_PIN 19
#define ORIG_X_MIN_PIN 25
#define ORIG_X_MAX_PIN -1
#define ORIG_Y_STEP_PIN 30
#define ORIG_Y_DIR_PIN 31
#define ORIG_Y_ENABLE_PIN 18
#define ORIG_Y_MIN_PIN 26
#define ORIG_Y_MAX_PIN -1
#define ORIG_Z_STEP_PIN 32
#define ORIG_Z_DIR_PIN 33
#define ORIG_Z_ENABLE_PIN 17
#define ORIG_Z_MIN_PIN -1
#define ORIG_Z_MAX_PIN 27
#define ORIG_E0_STEP_PIN 34
#define ORIG_E0_DIR_PIN 35
#define ORIG_E0_ENABLE_PIN 13
#define TEMP_0_PIN 7 // Extruder - ANALOG PIN NUMBER!
#define TEMP_1_PIN 6 // Bed - ANALOG PIN NUMBER!
#define HEATER_0_PIN 15 // Extruder
#define HEATER_1_PIN 14 // bed
#define HEATER_2_PIN -1
#define TEMP_2_PIN -1
#define SDPOWER -1
#define SDSS 20
#define LED_PIN -1
#define ORIG_FAN_PIN 16 // Fan
#define ORIG_PS_ON_PIN -1
#define E0_PINS ORIG_E0_STEP_PIN,ORIG_E0_DIR_PIN,ORIG_E0_ENABLE_PIN,
#define E1_PINS
#if !SDSUPPORT
// these pins are defined in the SD library if building with SD support
#define SCK_PIN 21
#define MISO_PIN 23
#define MOSI_PIN 22
