BTT K-Touch Display with Repetier
Hello everyone,
I'm wondering if it's possible to use the K-Touch Display with Repetier?
Product: https://de.aliexpress.com/item/1005007139023749.html
On the device itself you can scan the network for printers, so I've tried to scan for printers using port 3344 (as well as manually adding them), but unfortunately there's no klipper printers showing up, that are connected through repetier. Printers running mainsail show up right away.
It seems to be an ESP32, so I am currently assuming that I might have to install moonraker as in:
https://forum.repetier.com/discussion/11751/btt-knomi-with-repetier-server
Does anybody happen to have an idea as to how I can get this K-Touch working with repetier?
Thanks in advance
  • We do not run on displays we use the display offered by the pc you are running the server on.
    From what I read in the description it in deed connects to moonraker controlled api which is not compatible with our api. So this is a klipper only solution unless someone has writeen an alternative firmware for our api.
  • Thanks for looking into it.
    So you don't think I could get this running even if I did install moonraker correctly, understood.
    Thats unfortunate but thanks for the swift response!
  • With moonraker it works but we can currently not work with moonraker. And also when we support moonraker you would not see our data just the klipper status and local files.
