Shared G-code Groups for Printers
We've got 3 Printers of the same Kind and we would love to share G-code between the Printers.
Our Workflow is, that we Upload directly from the slicer to the Server and then start die Print with the Raspi Touch Panel next to the Printers. And if the Printer we Sliced for is already in Use, we've got to Slice again or Manually Download and Reupload the G-code, but not every User who Slices G-code has Webpanel Access.
So it would be great if there could be Shared Groups for G-code.
  • If all printers are on the same server instance you can do that already. One of them must be the main g-code storage and for the other 2 you deactivate in Printer Settings->General->General the option "Use own G-Code Directory" and then select the printer whos g-codes you want to use instead.
