Raspberry Pi5, Repetier Server 1.4.18, Pi Imager, not booting, Failed to start kernel-command-line
edited October 2024 in Repetier-Server
Hi
i have a new pi5 with 4gb ram.
an original pi5 psu
no printer connected yet.
the pi sd card is flashed with the image 1.4.18 v38 from pi imager.
when i start the pi, it tries to boot but stops after around 10 seconds and shutdown again.
i checked the boot log, see it as a quote.
pls help me to fix it .
sudo cat boot.log
------------ Mon Jul 15 14:03:59 GMT 2024 ------------
/scripts/local-premount/firstboot: 11: /scripts/local-premount/firstboot: grep: not found
e2fsck 1.47.0 (5-Feb-2023)
rootfs: clean, 188312/358336 files, 1148723/1425640 blocks
/scripts/local-bottom/imager_fixup: 13: /scripts/local-bottom/imager_fixup: grep: not found
         Mounting proc-sys-fs-binfm…utable File Formats File System...
[  OK  ] Mounted proc-sys-fs-binfmt…ecutable File Formats File System.
[  OK  ] Finished systemd-binfmt.se… Set Up Additional Binary Formats.
[  OK  ] Finished systemd-tmpfiles-…te Volatile Files and Directories.
         Starting modprobe@dm_mod.s…[0m - Load Kernel Module dm_mod...
         Starting modprobe@efi_psto…- Load Kernel Module efi_pstore...
         Starting modprobe@loop.ser…e - Load Kernel Module loop...
         Starting systemd-update-ut…rd System Boot/Shutdown in UTMP...
[  OK  ] Finished modprobe@dm_mod.s…e - Load Kernel Module dm_mod.
[  OK  ] Finished modprobe@efi_psto…m - Load Kernel Module efi_pstore.
[  OK  ] Finished modprobe@loop.service - Load Kernel Module loop.
[  OK  ] Finished systemd-update-ut…cord System Boot/Shutdown in UTMP.
[  OK  ] Reached target sysinit.target - System Initialization.
         Starting alsa-restore.serv…- Save/Restore Sound Card State...
         Starting kernel-command-li…ommand from Kernel Command Line...
[  OK  ] Started mjpg_streamer.serv…mjpg_streamer for Repetier-Server.
[  OK  ] Finished alsa-restore.serv…m - Save/Restore Sound Card State.
[FAILED] Failed to start kernel-com… Command from Kernel Command Line.
See 'systemctl status kernel-command-line.service' for details.
[DEPEND] Dependency failed for kern… Command from Kernel Command Line.
[  OK  ] Removed slice system-modpr…lice - Slice /system/modprobe.
[  OK  ] Stopped systemd-ask-passwo…uests to Plymouth Directory Watch.
         Stopping alsa-restore.serv…- Save/Restore Sound Card State...
         Stopping mjpg_streamer.ser…pg_streamer for Repetier-Server...
         Starting plymouth-poweroff… Show Plymouth Power Off Screen...
         Stopping systemd-random-se…ice - Load/Save Random Seed...
         Stopping systemd-rfkill.se…Load/Save RF Kill Switch Status...
[  OK  ] Stopped mjpg_streamer.serv…mjpg_streamer for Repetier-Server.
[  OK  ] Stopped systemd-rfkill.ser…- Load/Save RF Kill Switch Status.
[  OK  ] Stopped alsa-restore.servi…m - Save/Restore Sound Card State.
[  OK  ] Stopped target sysinit.target - System Initialization.
[  OK  ] Stopped target cryptsetup.…get - Local Encrypted Volumes.
[  OK  ] Stopped target integrityse…Local Integrity Protected Volumes.
[  OK  ] Stopped target swap.target - Swaps.
[  OK  ] Stopped target veritysetup… - Local Verity Protected Volumes.
[  OK  ] Closed systemd-rfkill.sock…l Switch Status /dev/rfkill Watch.
         Stopping fake-hwclock.serv…estore / save the current clock...
         Stopping systemd-binfmt.se…et Up Additional Binary Formats...
[  OK  ] Stopped systemd-sysctl.service - Apply Kernel Variables.
[  OK  ] Stopped systemd-modules-lo…service - Load Kernel Modules.
         Stopping systemd-update-ut…rd System Boot/Shutdown in UTMP...
[  OK  ] Unmounted run-credentials-…redentials/systemd-sysctl.service.
[  OK  ] Stopped fake-hwclock.servi… Restore / save the current clock.
[  OK  ] Started plymouth-poweroff.… - Show Plymouth Power Off Screen.
[  OK  ] Stopped systemd-binfmt.ser… Set Up Additional Binary Formats.
[  OK  ] Unset automount proc-sys-f…rmats File System Automount Point.
[  OK  ] Stopped systemd-random-see…rvice - Load/Save Random Seed.
[  OK  ] Stopped systemd-update-utm…cord System Boot/Shutdown in UTMP.
[  OK  ] Stopped systemd-tmpfiles-s…te Volatile Files and Directories.
[  OK  ] Stopped target local-fs.target - Local File Systems.
         Unmounting boot-firmware.mount - /boot/firmware...
         Unmounting run-credentials…ntials/systemd-sysusers.service...
         Unmounting run-credentials…/systemd-tmpfiles-setup.service...
         Unmounting run-credentials…temd-tmpfiles-setup-dev.service...
[  OK  ] Unmounted run-credentials-…dentials/systemd-sysusers.service.
[  OK  ] Unmounted boot-firmware.mount - /boot/firmware.
[  OK  ] Unmounted run-credentials-…ls/systemd-tmpfiles-setup.service.
[  OK  ] Stopped systemd-fsck@dev-d…/dev/disk/by-partuuid/e6dce604-01.
[  OK  ] Removed slice system-syste… - Slice /system/systemd-fsck.
[  OK  ] Unmounted run-credentials-…ystemd-tmpfiles-setup-dev.service.
[  OK  ] Stopped target local-fs-pr…reparation for Local File Systems.
[  OK  ] Reached target umount.target - Unmount All Filesystems.
[  OK  ] Stopped systemd-tmpfiles-s…reate Static Device Nodes in /dev.
[  OK  ] Stopped systemd-sysusers.service - Create System Users.
[  OK  ] Stopped systemd-remount-fs…ount Root and Kernel File Systems.
[  OK  ] Reached target shutdown.target - System Shutdown.
[  OK  ] Reached target final.target - Late Shutdown Services.
[  OK  ] Finished systemd-poweroff.service - System Power Off.
[  OK  ] Reached target poweroff.target - System Power Off.
edit:
additional information
i set in the pi imager the wifi credentials, ssh aceess, host name and user
  • This is the content of the comandline.txt
    console=tty1 root=PARTUUID=e6dce604-02 rootfstype=ext4 fsck.repair=yes rootwait quiet plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB logo.nologo quiet splash plymouth.ignore-serial-consoles spidev.bufsiz=8192 cfg80211.ieee80211_regdom=MT systemd.run=/boot/firstrun.sh systemd.run_success_action=reboot systemd.unit=kernel-command-line.target
  • > i set in the pi imager the wifi credentials, ssh aceess, host name and user
    I never do this, I use the original content. We did not modify this to make it work. We have a own solution to set all this, so maybe that is the problem. Have the image working on my pi 5 so hope this is it.
    Also note that it will reboot after first start when filesystem is expanded, so do not stop during this or image might be corrupt. Should restart and then come up with display etc.
    just tried without the settings out of the box, that works.
    with these settings even the filesystem didnt expand.
    now i will check the rest of the setup
