resetier-server le potato img
salve, mi chiedevo se fosse possibile avere una img di repertier-server da installare su le potato board???? ho provato con i vari forum ad installarlo ma, purtroppo, scarseggio nelle capacità di programmazione...
grazie in anticipo!!!!!
  • No, our image will work only on RaspberrzßPi boards since it is based on RaspbianOS which is optimiyed for them.
    However if you install an official image you can install the according linux packe if the image is debian like (using .deb packages). Do not know th eboard but likely the armhf or armhf 64 bit package will work, depending on the os.
