dualhead not working correctly
I am using a chimera dual printhead with repethier host v1.6.0 and slicer 1.2.9.
When i assign printhead 1 (extruder 0 that is) it does not specify it in the G-code and so the printer heats both and uses nr 2
When i assign printhead 2 (extruder 1 that is) is does specify it in the G-code and the printer only heats nr 2 and uses that one.
I did not remember having this problem in the previous version. Any idea's what i could be doing wrong?
Manually editting the g-code works.
