EEPROM read/write
It would be nice to have access to stored data in eeprom.
Bye
  • If you are printer check the printer menu. It has a eeprom settings function for this. Works only with repetier-firmware.
  • I have uploaded repetier firmware and I still can't set the eeprom function. I can run the printer from repetier so it mets be connected ok. Do I have to set any jumpers to do it? I have a Melzi 1.1 board
  • No jumper required. Send manually M205 and see what logs show. Should output the list of eeprom values if correctly compiled.
