not sure what settings I need from RH to RS
I have been using Repetier-host for a while now and I know how to setup my printer. I just started working with Repetier-server and I can connect, but I dont quite understand what the settings are on the printer size,shape etc.
For example here are my setting in RH
https://drive.google.com/open?id=0B7D6IsJcCSRMMmt5Q005dTZWZXc
https://drive.google.com/open?id=0B7D6IsJcCSRMOXhzRm44UGV6QzA
I am not sure which settings are supposed to line up with the servers settings
https://drive.google.com/open?id=0B7D6IsJcCSRMMV9Ha2NnYUc2SXM
https://drive.google.com/open?id=0B7D6IsJcCSRMMGVNS19xUTRRZzQ
any help would be appreciated.
  • Just enter what the printer thinks and has set.
    Bed shape is what you see and should be that area that is really printable. xyz min/max is what you can reach and for some printers this is more then the printable area. It is never less!
    Features of your printer should be obvious. Acceleration/buffer are for better time prediction. If you do not know them nothing bad happens just timing might be more off.
