multiple fill % in same model
Hi all. New to this forum; hope I'm in the right place!
Using Repetier-Host on Windows to create gcode for stl model created in OnShape (or Fusion360) [if it matters]. I would like to print most of the model using 75% fill, but a portion of it needs to be 100% fill. Is that something that's possible in the slicer? Or do I need to play games with creating separate models and somehow join them to produce a single gcode result? TIA for any light you can shed on this!
No one model. It has a feature to assign parameter to intersection with other volumes. For this it has e.g. boxes predefined which you can position. Not standard method but more for rare cases where wuch things are needed. Alternatively you can split object into multiple and assign them different settings as well.
