Update Problem Repetier-Server Pro 1.4.14
Hi , Update does not work , wehter by GUI nor by CLI ,
Any ideas ?
Installation was done earlier by raspberry image
pi@repetier-server:~ $ repetier-setup
rm: cannot remove 'RepetierServerLatest.deb': No such file or directory
Raspberry with v7 or newer command set found. Installing armhf version...
--2024-04-08 16:15:17-- http://download.repetier.com/files/server/debian-armhf/RepetierServerLatest.deb
Resolving download.repetier.com (download.repetier.com)... 188.138.1.8, 94.130.164.39
Connecting to download.repetier.com (download.repetier.com)|188.138.1.8|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 54089958 (52M) [application/octet-stream]
Saving to: ‘RepetierServerLatest.deb’
RepetierServerLatest.deb 100%[=======================================================================================================================>] 51.58M 9.25MB/s in 5.3s
2024-04-08 16:15:22 (9.66 MB/s) - ‘RepetierServerLatest.deb’ saved [54089958/54089958]
dpkg: warning: files list file for package 'lxplug-network' missing; assuming package has no files currently installed
dpkg: unrecoverable fatal error, aborting:
files list file for package 'libgdk-pixbuf-2.0-0:armhf' contains empty filename
Press any key to continue
Any ideas ?
