Format Error , Wrong Checksum , Extrusion Stops
I keep getting a repeated message throughout the logs with no obvious pattern or predictability.
Error: Wrong Checksum
Resend ....
Error: Format Error
Resend ...
I can run the same print twice off the same slice and the errors occur on different lines
The errors occur on different objects sliced on slic3r and cura
On about half the prints this error repeating eventually results in a momentary pause and the extruder will swap from 1 to 2 or 2 to 1 ( you can watch the offset change) and motion continues with no printing. Heat stays on but nothing extrudes.
I re-downloaded both the Host and the Firmware newest versions, no change.
Error occurs in both Windows 8.1 and Windows 10 on the same notebook.
Custom Build printer no kit or premade
relevant hardware:
-Ramps 1.4
-reprap discount LCD
-fan extender
-shielded USB cable
Baud rate 250000
Short of removing/replacing hardware I can't seem to find any pattern or problem location.
Any help is greatly appreciated.
I ran the usb cable under the printer to avoid interference. There is about 50 mm and a 8mm thick sheet of uhmw between the usb and all components.
The errors themselves are not really a problem, it's the extruder switch and ruined prints.
I toyed around with cura host and could not reproduce the error with the same firmware, baudrate, and usb cable after a dozen test prints.
I'll attempt running a lower baud rate tonight.
I'll skeptical though. I've been running the same hardware for months minus the fan extender. The failed prints started in the last 2 weeks
Error:No Checksum with line number, Last Line: 29 Recv: Resend: 30
What should I do to avoid it ????(i use inkscape and Makercam to upload the design to Repetier ) thanks
If it was just a communication error host would resend the line and it would continue.
