Freezer temperature controller
in News
Temperature controller is a measurement device used on temperature control. Thermocouple-type and resistor-type temperature controllers measure temperature electronically, obtaining the temperature change from the sensor and sending the measured data to the electronic processor. The output device will then control the temperature variation within a specific range.
Freezer temperature controller is equipped with an expansion tank for separating generated bubbles from engine coolant. Furthermore, there is the reservoir function of the expansion tank. It can ensure sufficient engine coolant circulation amount.
