Mac version is an separate software which needs a separate programming, so it is not a simple compile for mac. It is spend some month development for the next update type of update. Having said that, we are working hard on a new version, but we can not say when it will happen. My guess is in 1-2 month for a first updated version. From then on we want to increase update frequency also for mac.
That would be a lot easier to take if it hadn't been so very long since you released a Mac update previously. You repeatedly chose to release Windows/Linux updates while allowing the Mac version to fall behind. Can you at least assure Mac users that you'll be more even-handed about keeping Mac at release parity in the future?
Sorry, prior msg sounded a bit harsher than I'd intended, I only meant it a little bit harsh (which seemed fair under the circumstances). I really do prefer Repetier-Host, but only if the Mac version is kept at release parity with the Win version.
Unfortunately the server development took more time then planned. Good news is the server is out and also works on Mac and will be updated in the same cycle as other server platforms, simply because it is the same code for all platforms. So over short the server is the preferred way to print. Plan is to add an interface to the hosts to send jobs directly to servers.
http://www.mattercontrol.com/
ein Lichtlein brennt.
Erst eins, dann zwei,
dann drei, dann vier,
dann steht das Christkind mit dem Repetier vor der Tür.
Plan to release soon ?
I've just build a k8400 and I must use Windows to use it it's boring !!
I will use matter control or simplify 3D, they both run on Mac osX !
