4K Timelapse Resolution still HD ?
I have a RPi3 connected with a Logitech Brio 4K Webcamera, and that all works OK.
I have set the resolution to be 4K in the camera setup i.e. 3840 x 2160 but the JPEG's being shot during a timelaps are still just 1920 x 1080 ?
Any ideas where I need to look etc ?
Please with that resolution reduce framerate to 5FPS or you get issues with amount of data as MJPG stream.
https://www.raspberrypi.com/products/raspberry-pi-3-model-b/
pi 3 has only 4 USB2 ports. Using a usb3 switch will downgrade it therefore to USB2.
Under Printer Settings, webcam I have the resolution set to 4096x2160 and 1FPS
Now printing and taking images at 1920 x 1080 :-(
I get ...
Start from directory /usr/local/Repetier-Setup/bin
Testing for active webcams in /dev/v4l/by-path/*
Best resolution: 4096 x 2160 at 5
./watchedCam 8080 /dev/video0 5 4096x2160
Webcam does not support MJPG - using slower YUYV instead!
So if I want to shoot 4K timelapse I will need a different camera ?
/usr/bin/v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
[1]: 'MJPG' (Motion-JPEG, compressed)
Interval: Discrete 0.008s (120.000 fps)
Interval: Discrete 0.011s (90.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 2560x1440
Size: Discrete 3840x2160
Size: Discrete 4096x2160
[2]: 'NV12' (Y/UV 4:2:0)
So will see tomorrow how it behaves with new image now.
and still image is 4k. But the webcam is a bit difficult as it seems not to change as wanted. We needed to remove and reinsert usb plug to use new settings. And often on reboot we also need to reconnect it to work.
The message
is independent of that cam. It comes from a test of other listed video devices. When process is listed with input_uvc module it uses mjpg.
