The slicer flow rate settings are often ignored
... yeah yeah yeah... me again...
Strangely enough, sometimes it works, but despite intensive searching, I just can't figure out under what circumstances it works and when it doesn't.
Is that just me?
Despite the fact that on connection start we set it to 100% we do not block it. Except if at some point firmware says M221 is not supported after that we would filter M221. You can send M221 any time and we even show the correct flow rate.
I've now sliced something simple in CURA. In CURA it is set that the first layer should be printed with 95% and all other layers with 90% flow rate. I saved that as a gCode and searched for M221... Nothing... nada...
So this seems to be a BUG or a setting issue in CURA. Because as I said: sometimes it works
Now I'm more confused as before ...
Also note that we do not reset it once it was changed it stays until someone sends a different value.
