G-Code file upload problem
I have just installed the latest
Repetier Server on a Windows 7 machine and connected to the Delta
printer
controlled by Arduino Mega 2560. Everything is working fine except G-Code
file upload. Every
time I upload G-code file, I
receive such notification (‘Failed to remove finished job file
C:\ProgramData\RepetierServer\printer\bingo\models\00000030_holder1.g’).
Eventually, Stored G-code File list screen
fails to show files that I intend to upload. However,
if I restart Repetier sever
service and log on to the server again, uploaded files are properly shown
on Stored
G-code list box. I’ll be looking
forward to hearing from you for any assistance you might
provide.
Creating new job caused error ...
or
Creating new model caused error ...
Only after such an error, the server will try to delete the uploaded files. A typical reason would be a permission denied if the folder is not read/writable by the servers user. So make sure you did not copy files yourself to it - the server does not run with your account.
I've installed server 0.650 and I have made several attempts to upload G-code function in another desktop and notebook of windows 7. The results were all the same. Direct printing works remarkably well but 'upload model ' seems to be a failure. Error message in server log file is as follows. I did not copy any files by myself. How to fix 'Creating new model caused error ...' ??
-----------------------------------------------------------------------------------------------------------------------------------------------------------------2015-10-06 21:58:30: Start logging...
2015-10-06 21:58:30: Webdirectory: C:\Program Files\Repetier-Server\www\
2015-10-06 21:58:30: Storage directory: C:\ProgramData/Repetier-Server\
2015-10-06 21:58:30: Configuration file: C:\Program Files\Repetier-Server\bin\RepetierServer.xml
2015-10-06 21:58:30: Directory for temporary files: C:\Windows\Temp\
2015-10-06 21:58:30: Reading firmware data ...
2015-10-06 21:58:30: Starting Network ...
2015-10-06 21:58:30: Reading printer configurations ...
2015-10-06 21:58:30: Starting printer threads ...
2015-10-06 21:58:30: Starting work dispatcher subsystem ...
2015-10-06 21:58:30: WorkDispatcher table created successfully
2015-10-06 21:58:30: Starting user database ...
2015-10-06 21:58:30: Initalizing LUA ...
2015-10-06 21:58:30: Starting web server ...
2015-10-06 21:58:30: Webserver started.
2015-10-06 21:59:28: Job created: C:\ProgramData/Repetier-Server\printer\dP150A\models/00000001_.u
2015-10-06 21:59:28: Creating new model caused error Assertion violation
2015-10-06 21:59:29: input stream size: 8378680
2015-10-06 21:59:29: Output stream size: 8378680
2015-10-06 21:59:29: Job created: C:\ProgramData/Repetier-Server\printer\dP150A\models/00000002_AngelStatue2_fixed.u
2015-10-06 21:59:29: finish job C:\ProgramData/Repetier-Server\printer\dP150A\models/00000002_AngelStatue2_fixed.u
2015-10-06 21:59:29: Updating info for C:\ProgramData/Repetier-Server\printer\dP150A\models/00000002_AngelStatue2_fixed.g printer dP150A
2015-10-06 21:59:29: Creating new model caused error File not found
2015-10-06 21:59:29: error: Failed to remove finished job C:\ProgramData/Repetier-Server\printer\dP150A\models/00000002_AngelStatue2_fixed.g
2015-10-06 21:59:29: Handling action 'listModels' caused error File not found
2015-10-06 21:59:29: LUA job rendering.render#{"id":2,"image":"C:\\ProgramData/Repetier-Server\\printer\\dP150A\\models/00000002_AngelStatue2_fixed_l.png","layer":"C:\\ProgramData/Repetier-Server\\printer\\dP150A\\models/00000002_AngelStatue2_fixed.layer","list":"models","slug":"dP150A"}
2015-10-06 21:59:29: Reading configuration file ...
Input file: C:\ProgramData/Repetier-Server\printer\dP150A\models/00000002_AngelStatue2_fixed.layer
system exception
1) Directory status after server start
C:\ProgramData\Repetier-Server\configs : dP150A.xml
C:\ProgramData\Repetier-Server\database : rederer.json settings.sql user.sql workdispatcher.sql
C:\ProgramData\Repetier-Server\logs : sever.logs
C:\ProgramData\Repetier-Server\printer\dP150A\data : vacant
C:\ProgramData\Repetier-Server\printer\dP150A\jobs : vacant
C:\ProgramData\Repetier-Server\printer\dP150A\logs : vacant
C:\ProgramData\Repetier-Server\printer\dP150A\models : vacant
C:\ProgramData\Repetier-Server\tmp : vacant
2) I Uploaded G-code file 'AngelStatue2.gcode'
3) Upload finished pop up message 2 times.
4) Message icon notify ' dP150A Failed to remove finished jon file ......'.
5) Directory status : all same except models directory
C:\ProgramData\Repetier-Server\printer\dP150A\models : 00000006_AngelStatue2.g 00000006_AngelStatue2.gin 00000006_AngelStatue2.layer 00000006_AngelStatue2.linfo 00000006_AngelStatue2_l.png 00000006_AngelStatue2_m.pnf
Thanks for your reply.
