Custom Klipper
My printer has a DWIN display and requires a custom version of Klipper to work with the display. (https://github.com/Desuuuu/klipper) Only versions approved by Repetier are available for selection when using the Klipper/Install when adding a new printer. How can I use a custom Klipper implementation?
  • Easiest solution is to install stock klipper version. This will land in folder /opt/klipper/<PriunterSLug>
    Then get your klipper version files and copy them over the existing installation and then start compiling printer firmware stub etc. Restaring klipper might be required (or rebooting pi).
