Issue with shutdown from the web interface
Happy new year everybody,
following the faq: https://www.repetier-server.de/faq/upgrade-to-our-latest-pi-image/ I've set up a new image using Debian Bookworm Raspi-image 64 bit and the latest Repetier-Server-1.4.15-Linux.deb (not the Raspi image).
Everything as expected, backing up and restore /var/lib worked like a charme.
However there is a small issue with the server shutdown now using the corresponding command in the web-ui: "Shutdown Server": It turned out that the server ignores the request. From ssh requesting the service status, I saw the message below.
pi@repetier:~ $ sudo service RepetierServer status
● RepetierServer.service - Repetier-Server 3D Printer Server
Loaded: loaded (/lib/systemd/system/RepetierServer.service; enabled; preset: enabled)
Active: active (running) since Sun 2024-01-07 21:22:09 CET; 1h 27min ago
Main PID: 659 (RepetierServer)
Tasks: 22
CPU: 1min 48.994s
CGroup: /system.slice/RepetierServer.service
└─659 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
Jan 07 21:22:08 repetier systemd[1]: Starting RepetierServer.service - Repetier-Server 3D Printer Server...
Jan 07 21:22:09 repetier systemd[1]: Started RepetierServer.service - Repetier-Server 3D Printer Server.
Jan 07 22:49:25 repetier sudo[3945]: pam_unix(sudo:auth): conversation failed
Jan 07 22:49:25 repetier sudo[3945]: pam_unix(sudo:auth): auth could not identify password for [repetierserver]
Jan 07 22:49:25 repetier sudo[3945]: repetierserver : command not allowed ; PWD=/ ; USER=root ; COMMAND=/sbin/shutdown -h now
pi@repetier:~ $
What may I change to have the command working as expected?
Here's the command entry from /var/lib/Repetier-Server/database/extcommands.xml (without icon CData)
<command>
<name>Shutdown Server</name>
<icon>...</icon>
<execute>sudo /sbin/shutdown -h now</execute>
<confirm>Really shut down the server?</confirm>
<!-- Define if command should show up in local printer interface, default true.-->
<local>true</local>
<!-- Define if command should show up in remote printer interface, default true.-->
<remote>true</remote>
<!-- Define if command should show up only for users with print permission, default true.-->
<print-permission>true</print-permission>
<!-- Define if command should show up only for users with add files permission, default false.-->
<add-permission>true</add-permission>
<!-- Define if command should show up only for users with del files permission, default false.-->
<del-permission>true</del-permission>
<!-- Define if command should show up only for users with configuration permission, default false.-->
<config-permission>true</config-permission>
</command>
Thank you in advance.
Best regards,
Gerald
