Kobra Max - immer wieder nervige Abbrüche...
Hallo,
ich habe bei meinem Anycubic Kobra Max immer wieder nervige Druckabbrüche mitten im Druck.
Das ganze passiert aber leider immer sporadisch.
Ich habe den Log vom letzten Abbruch gespeichert und ein Foto von meinen Einstellungen gemacht.
Vermutlich sitzt das Problem vorm PC, aber kann mir hier mal einen Tipp geben wie man das ganze bei den Kobra Max richtig einstellt?
Ich habe nach einem Mainboard Defekt ein neues Trigorilla Board bekommen mit der Firmware 3.0.4 (zur Info):
https://imgur.com/a/r0KlGwd
Mesg:16:57:06.204: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:06.204: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:06.204: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:06.204: Connection status: Buffered:40, Manual Commands: 0, Job Commands: 5000
Mesg:16:57:06.204: Buffer used:40 Enforced free byte:0 lines stored:1
Mesg:16:57:13.216: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:13.216: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:13.216: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:13.216: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:16:57:13.216: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:57:13.557: Received extra ok - ignored
Recv:16:57:13.558: echo:Unknown command: "2675"
Mesg:16:57:20.979: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:20.979: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:20.979: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:20.979: Connection status: Buffered:39, Manual Commands: 1, Job Commands: 5000
Mesg:16:57:20.979: Buffer used:39 Enforced free byte:0 lines stored:1
Mesg:16:57:27.982: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:27.982: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:27.982: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:27.982: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:16:57:27.982: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:57:28.760: Received extra ok - ignored (3)
Mesg:16:57:35.770: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:35.770: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:35.770: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:35.770: Connection status: Buffered:40, Manual Commands: 0, Job Commands: 5000
Mesg:16:57:35.770: Buffer used:40 Enforced free byte:0 lines stored:1
Mesg:16:57:42.775: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:42.775: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:42.775: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:42.775: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:57:42.775: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:57:43.121: Received extra ok - ignored (2)
Mesg:16:57:50.545: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:50.545: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:50.545: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:50.545: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:57:50.545: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:57:57.550: Warning: Communication timeout - resetting communication buffer.
Mesg:16:57:57.550: This means that a expected firmware response was not seen within the expected time.
Mesg:16:57:57.550: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:57:57.550: Connection status: Buffered:25, Manual Commands: 0, Job Commands: 5000
Mesg:16:57:57.550: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:57:58.325: Received extra ok - ignored
Mesg:16:58:05.340: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:05.340: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:05.340: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:05.340: Connection status: Buffered:39, Manual Commands: 0, Job Commands: 5000
Mesg:16:58:05.340: Buffer used:39 Enforced free byte:0 lines stored:1
Mesg:16:58:12.347: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:12.347: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:12.347: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:12.347: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:58:12.347: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:58:13.107: Received extra ok - ignored
Mesg:16:58:20.112: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:20.112: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:20.112: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:20.112: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:58:20.112: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:58:27.123: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:27.123: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:27.123: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:27.123: Connection status: Buffered:25, Manual Commands: 0, Job Commands: 5000
Mesg:16:58:27.123: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:58:27.471: Received extra ok - ignored
Recv:16:58:27.474: Error:checksum mismatch, Last Line: 8987
Recv:16:58:27.474: Resend: 8988
Mesg:16:58:34.901: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:34.901: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:34.901: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:34.901: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:58:34.901: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:58:41.921: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:41.921: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:41.921: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:41.921: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:16:58:41.921: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:58:42.252: Received extra ok - ignored
Recv:16:58:42.256: echo:Unknown command: "68.423 Y263.546 E94.2993"
Mesg:16:58:49.686: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:49.686: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:49.686: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:49.686: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:58:49.686: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:58:56.693: Warning: Communication timeout - resetting communication buffer.
Mesg:16:58:56.693: This means that a expected firmware response was not seen within the expected time.
Mesg:16:58:56.693: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:58:56.693: Connection status: Buffered:17, Manual Commands: 0, Job Commands: 5000
Mesg:16:58:56.693: Buffer used:17 Enforced free byte:0 lines stored:1
Mesg:16:58:57.035: Received extra ok - ignored
Mesg:16:59:04.463: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:04.463: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:04.463: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:04.463: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:04.463: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:59:11.469: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:11.469: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:11.469: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:11.469: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:11.469: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:16:59:12.237: Received extra ok - ignored (2)
Mesg:16:59:19.240: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:19.240: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:19.240: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:19.240: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:19.240: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:59:26.252: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:26.252: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:26.252: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:26.252: Connection status: Buffered:17, Manual Commands: 0, Job Commands: 5000
Mesg:16:59:26.252: Buffer used:17 Enforced free byte:0 lines stored:1
Recv:16:59:26.604: Error:Line Number is not Last Line Number+1, Last Line: 8995
Recv:16:59:26.607: Resend: 8996
Mesg:16:59:34.025: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:34.025: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:34.025: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:34.025: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:34.025: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:59:41.037: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:41.037: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:41.037: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:41.037: Connection status: Buffered:17, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:41.037: Buffer used:17 Enforced free byte:0 lines stored:1
Mesg:16:59:41.383: Received extra ok - ignored
Recv:16:59:41.385: echo:Unknown command: "E109.54575"
Mesg:16:59:48.818: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:48.818: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:48.818: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:48.818: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:16:59:48.818: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:16:59:55.819: Warning: Communication timeout - resetting communication buffer.
Mesg:16:59:55.819: This means that a expected firmware response was not seen within the expected time.
Mesg:16:59:55.819: The typical reason is a communication error and print should continue after the communication reset.
Mesg:16:59:55.819: Connection status: Buffered:18, Manual Commands: 0, Job Commands: 5000
Mesg:16:59:55.819: Buffer used:18 Enforced free byte:0 lines stored:1
Mesg:16:59:56.165: Received extra ok - ignored
Mesg:17:00:03.591: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:03.591: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:03.591: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:03.591: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:03.591: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:00:10.597: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:10.597: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:10.597: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:10.597: Connection status: Buffered:17, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:10.597: Buffer used:17 Enforced free byte:0 lines stored:1
Mesg:17:00:11.368: Received extra ok - ignored (2)
Mesg:17:00:18.382: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:18.382: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:18.382: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:18.382: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:18.382: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:00:25.396: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:25.396: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:25.396: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:25.396: Connection status: Buffered:18, Manual Commands: 0, Job Commands: 5000
Mesg:17:00:25.396: Buffer used:18 Enforced free byte:0 lines stored:1
Recv:17:00:25.735: Error:Line Number is not Last Line Number+1, Last Line: 9003
Recv:17:00:25.738: Resend: 9004
Mesg:17:00:33.152: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:33.152: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:33.152: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:33.152: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:33.152: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:00:40.153: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:40.153: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:40.153: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:40.153: Connection status: Buffered:18, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:40.153: Buffer used:18 Enforced free byte:0 lines stored:1
Mesg:17:00:40.513: Received extra ok - ignored
Recv:17:00:40.515: echo:Unknown command: "6 E124.79221"
Mesg:17:00:47.942: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:47.942: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:47.942: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:47.942: Connection status: Buffered:41, Manual Commands: 0, Job Commands: 5000
Mesg:17:00:47.942: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:00:54.947: Warning: Communication timeout - resetting communication buffer.
Mesg:17:00:54.947: This means that a expected firmware response was not seen within the expected time.
Mesg:17:00:54.947: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:00:54.947: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:00:54.947: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:00:55.295: Received extra ok - ignored
Mesg:17:01:02.729: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:02.729: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:02.729: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:02.729: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:02.729: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:01:09.737: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:09.737: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:09.737: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:09.737: Connection status: Buffered:18, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:09.737: Buffer used:18 Enforced free byte:0 lines stored:1
Mesg:17:01:10.077: Received extra ok - ignored
Mesg:17:01:17.508: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:17.508: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:17.508: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:17.508: Connection status: Buffered:41, Manual Commands: 0, Job Commands: 5000
Mesg:17:01:17.508: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:01:24.515: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:24.515: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:24.515: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:24.515: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:24.515: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:01:24.860: Received extra ok - ignored
Recv:17:01:25.286: Error:Line Number is not Last Line Number+1, Last Line: 9011
Recv:17:01:25.288: Resend: 9012
Mesg:17:01:32.334: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:32.334: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:32.334: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:32.334: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:32.334: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:01:39.338: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:39.338: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:39.338: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:39.338: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:39.338: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:01:39.642: Received extra ok - ignored
Mesg:17:01:46.646: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:46.646: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:46.646: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:46.646: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:46.646: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:17:01:53.651: Warning: Communication timeout - resetting communication buffer.
Mesg:17:01:53.651: This means that a expected firmware response was not seen within the expected time.
Mesg:17:01:53.651: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:01:53.651: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:01:53.651: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:02:00.662: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:00.662: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:00.662: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:00.662: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:02:00.662: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:02:07.676: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:07.676: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:07.676: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:07.676: Connection status: Buffered:18, Manual Commands: 0, Job Commands: 5000
Mesg:17:02:07.676: Buffer used:18 Enforced free byte:0 lines stored:1
Mesg:17:02:14.681: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:14.681: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:14.681: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:14.681: Connection status: Buffered:41, Manual Commands: 1, Job Commands: 5000
Mesg:17:02:14.681: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:02:21.695: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:21.695: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:21.695: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:21.695: Connection status: Buffered:17, Manual Commands: 1, Job Commands: 5000
Mesg:17:02:21.695: Buffer used:17 Enforced free byte:0 lines stored:1
Mesg:17:02:28.700: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:28.700: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:28.700: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:28.700: Connection status: Buffered:25, Manual Commands: 1, Job Commands: 5000
Mesg:17:02:28.700: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:17:02:35.707: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:35.707: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:35.707: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:35.707: Connection status: Buffered:18, Manual Commands: 0, Job Commands: 5000
Mesg:17:02:35.707: Buffer used:18 Enforced free byte:0 lines stored:1
Mesg:17:02:42.728: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:42.728: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:42.728: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:42.728: Connection status: Buffered:41, Manual Commands: 2, Job Commands: 7
Mesg:17:02:42.728: Buffer used:41 Enforced free byte:0 lines stored:1
Mesg:17:02:49.741: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:49.741: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:49.741: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:49.741: Connection status: Buffered:13, Manual Commands: 2, Job Commands: 7
Mesg:17:02:49.741: Buffer used:13 Enforced free byte:0 lines stored:1
Mesg:17:02:56.751: Warning: Communication timeout - resetting communication buffer.
Mesg:17:02:56.751: This means that a expected firmware response was not seen within the expected time.
Mesg:17:02:56.751: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:02:56.751: Connection status: Buffered:24, Manual Commands: 0, Job Commands: 7
Mesg:17:02:56.751: Buffer used:24 Enforced free byte:0 lines stored:1
Mesg:17:03:16.757: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:16.757: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:16.757: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:16.757: Connection status: Buffered:14, Manual Commands: 2, Job Commands: 5
Mesg:17:03:16.757: Buffer used:14 Enforced free byte:0 lines stored:1
Mesg:17:03:23.769: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:23.769: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:23.769: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:23.769: Connection status: Buffered:19, Manual Commands: 1, Job Commands: 5
Mesg:17:03:23.769: Buffer used:19 Enforced free byte:0 lines stored:1
Mesg:17:03:29.712: Full stop button pressed
Mesg:17:03:29.712: Printer reset requested - emergency:true
Mesg:17:03:29.840: Dtr: false Rts: false
Mesg:17:03:29.871: Dtr: true Rts: true
Mesg:17:03:36.722: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:36.722: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:36.722: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:36.722: Connection status: Buffered:25, Manual Commands: 3, Job Commands: 0
Mesg:17:03:36.722: Buffer used:25 Enforced free byte:0 lines stored:2
Mesg:17:03:43.732: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:43.732: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:43.732: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:43.732: Connection status: Buffered:25, Manual Commands: 3, Job Commands: 0
Mesg:17:03:43.732: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:17:03:50.738: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:50.738: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:50.738: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:50.738: Connection status: Buffered:14, Manual Commands: 2, Job Commands: 0
Mesg:17:03:50.738: Buffer used:14 Enforced free byte:0 lines stored:1
Mesg:17:03:57.744: Warning: Communication timeout - resetting communication buffer.
Mesg:17:03:57.744: This means that a expected firmware response was not seen within the expected time.
Mesg:17:03:57.744: The typical reason is a communication error and print should continue after the communication reset.
Mesg:17:03:57.744: Connection status: Buffered:25, Manual Commands: 0, Job Commands: 0
Mesg:17:03:57.744: Buffer used:25 Enforced free byte:0 lines stored:1
Mesg:17:05:16.415: Connection closed by os.
Mesg:17:05:19.836: Connection started
Mesg:17:05:19.836: Printer reset requested - emergency:false
Mesg:17:05:19.837: Dtr: false Rts: false
Mesg:17:05:19.872: Dtr: true Rts: true
Recv:17:05:22.877: Send init commands because we had no signal from a reset, assuming reset not available.
Mesg:17:05:33.592: Connection started
Mesg:17:05:33.592: Printer reset requested - emergency:false
Mesg:17:05:33.592: Dtr: false Rts: false
Mesg:17:05:33.620: Dtr: true Rts: true
Recv:17:05:36.630: Send init commands because we had no signal from a reset, assuming reset not available.
  • Sieht aus als ob du das aus Konsole kopiert hast. Ist recht unvollständig weil die Filter Befehle und Ack filtern. Wenn dann solltest du im Druckermemü Logs aktivieren und das log herunterladen um zu sehen wie es genau passiert.
    Interessant ist z.b. folgender Ausschnitt:
    Hier kommen offenbar mehr ok an als möglich bei Ping-Pong. Allerdings wird mit jedem Timeout auch mehr gesendet und kann den Druckerpuffer überfüllen wenn der Drucker blockiert. Ich sehe alle 7 Sekunden kommt ein Timeout - ist das dein Timeout?
    Unterstützt die Firmware busy Protokol? Aktiviere ack und sende
    G4 S20
    und wenn du Zeilen wie busy: ...
    siehst ist das wohl der Fall, sonst nicht und du solltest timeout erhöhen.
    Wenn du logging aktiviert hast must du dir ansehen wo das Timeout entsteht, also welcher Befehl dazu führt oder ob der Drucker in einen Fehlerstatus gegangen ist und daher nicht mehr entgegen nimmt.
  • Vielen Dank für die schnelle Rückmeldung,
    ich habe das Timeout auf 6 Sekunden definiert gehabt.
    Testweise habe ich es jetzt mal auf 15 Sekunden angehoben (was ist hier sinnvoll) und habe mit aktivierten Log den fehlgeschlagenen 16 Stunden Druck noch einmal gestartet.
    Der G-Code dürfte aber nicht fehlerhaft sein, von der SD-Karte hat alles geklappt.
    Das Busy Protokoll wird denke ich nicht unterstützt. Ich habe zumindest keine Busy Command nach aktivieren im Log entdeckt.
    Nachdem ich den Befehl eingegeben habe ist das erschienen, ich weiß aber nicht ob das zusammenhängt.
    Danke für die Hilfe!
    Send:17:44:19.571: N3283 G21
    Recv:17:44:19.574: ok (N3283)
    Send:17:44:19.574: N3284 G21
    Recv:17:44:19.577: ok (N3284)
    Send:17:44:19.577: N3285 G21
    Recv:17:44:19.580: ok (N3285)
    Send:17:44:19.580: N3286 G21
    Recv:17:44:19.583: ok (N3286)
    Send:17:44:19.583: N3287 G21
    Recv:17:44:19.586: ok (N3287)
    Send:17:44:19.586: N3288 G21
    Recv:17:44:19.588: ok (N3288)
    Send:17:44:19.589: N3289 G21
    Recv:17:44:19.591: ok (N3289)
    Send:17:44:19.591: N3290 G21
    Recv:17:44:19.594: ok (N3290)
    Send:17:44:19.594: N3291 G21
    Recv:17:44:19.597: ok (N3291)
    Send:17:44:19.597: N3292 G21
    Recv:17:44:19.600: ok (N3292)
    Send:17:44:19.600: N3293 G21
    Recv:17:44:19.603: ok (N3293)
    Send:17:44:19.603: N3294 G21
    Recv:17:44:19.606: ok (N3294)
    Send:17:44:19.606: N3295 G21
    Recv:17:44:19.609: ok (N3295)
    Send:17:44:19.609: N3296 G21
    Recv:17:44:19.612: ok (N3296)
    Send:17:44:19.612: N3297 G21
    Recv:17:44:19.615: ok (N3297)
    Send:17:44:19.615: N3298 G21
    Recv:17:44:19.618: ok (N3298)
    Send:17:44:19.618: N3299 G21
    Recv:17:44:19.621: ok (N3299)
    Send:17:44:19.621: N3300 G21
    Recv:17:44:19.624: ok (N3300)
    Send:17:44:19.624: N3301 G21
    Recv:17:44:19.627: ok (N3301)
    Send:17:44:19.627: N3302 G21
    Recv:17:44:19.630: ok (N3302)
    Send:17:44:19.630: N3303 G21
    Recv:17:44:19.633: ok (N3303)
    Send:17:44:19.633: N3304 G21
    Recv:17:44:19.636: ok (N3304)
    Send:17:44:19.636: N3305 G21
    Recv:17:44:19.639: ok (N3305)
    Send:17:44:19.639: N3306 G21
    Recv:17:44:19.642: ok (N3306)
    Send:17:44:19.642: N3307 G21
    Recv:17:44:19.644: ok (N3307)
    Send:17:44:19.644: N3308 G21
    Recv:17:44:19.647: ok (N3308)
    Send:17:44:19.647: N3309 G21
    Recv:17:44:19.650: ok (N3309)
    Send:17:44:19.650: N3310 G21
    Recv:17:44:19.653: ok (N3310)
    Send:17:44:19.653: N3311 G21
    Recv:17:44:19.656: ok (N3311)
    Send:17:44:19.656: N3312 G21
    Recv:17:44:19.660: ok (N3312)
    Send:17:44:19.660: N3313 G21
    Recv:17:44:19.662: ok (N3313)
    Send:17:44:19.662: N3314 G21
    Recv:17:44:19.665: ok (N3314)
    Send:17:44:19.665: N3315 G21
    Recv:17:44:19.668: ok (N3315)
    Send:17:44:19.668: N3316 G21
    Recv:17:44:19.671: ok (N3316)
    Send:17:44:19.671: N3317 G21
    Recv:17:44:19.674: ok (N3317)
    Send:17:44:19.674: N3318 G21
    Recv:17:44:19.677: ok (N3318)
    Send:17:44:19.677: N3319 G21
    Recv:17:44:19.681: ok (N3319)
    Send:17:44:19.681: N3320 G21
    Recv:17:44:19.683: ok (N3320)
    Send:17:44:19.684: N3321 G21
    Recv:17:44:19.687: ok (N3321)
    Send:17:44:19.687: N3322 G21
    Recv:17:44:19.690: ok (N3322)
    Send:17:44:19.690: N3323 G21
    Recv:17:44:19.694: ok (N3323)
    Send:17:44:19.694: N3324 G21
    Recv:17:44:19.697: ok (N3324)
    Send:17:44:19.697: N3325 G21
    Recv:17:44:19.701: ok (N3325)
    Send:17:44:19.701: N3326 G21
    Recv:17:44:19.704: ok (N3326)
    Send:17:44:19.704: N3327 G21
    Recv:17:44:19.707: ok (N3327)
    Send:17:44:19.707: N3328 G21
    Recv:17:44:19.711: ok (N3328)
    Send:17:44:19.711: N3329 G21
    Recv:17:44:19.714: ok (N3329)
    Send:17:44:19.714: N3330 G21
    Recv:17:44:19.717: ok (N3330)
    Send:17:44:19.717: N3331 G21
    Recv:17:44:19.720: ok (N3331)
    Send:17:44:19.720: N3332 G21
    Recv:17:44:19.723: ok (N3332)
    Send:17:44:19.723: N3333 G21
    Recv:17:44:19.726: ok (N3333)
    Send:17:44:19.726: N3334 G21
    Recv:17:44:19.729: ok (N3334)
    Send:17:44:19.729: N3335 G21
    Recv:17:44:19.732: ok (N3335)
    Send:17:44:19.732: N3336 G21
    Recv:17:44:19.735: ok (N3336)
    Send:17:44:19.735: N3337 G21
    Recv:17:44:19.739: ok (N3337)
    Send:17:44:19.739: N3338 G21
    Recv:17:44:19.741: ok (N3338)
    Send:17:44:19.742: N3339 G21
    Recv:17:44:19.745: ok (N3339)
    Send:17:44:19.745: N3340 G21
    Recv:17:44:19.747: ok (N3340)
    Send:17:44:19.747: N3341 G21
    Recv:17:44:19.750: ok (N3341)
    Send:17:44:19.750: N3342 G21
    Recv:17:44:19.753: ok (N3342)
    Send:17:44:19.753: N3343 G21
    Recv:17:44:19.756: ok (N3343)
    Send:17:44:19.756: N3344 G21
    Recv:17:44:19.759: ok (N3344)
    Send:17:44:19.759: N3345 G21
    Recv:17:44:19.762: ok (N3345)
    Send:17:44:19.762: N3346 G21
    Recv:17:44:19.765: ok (N3346)
    Send:17:44:19.765: N3347 G21
    Recv:17:44:19.768: ok (N3347)
    Send:17:44:19.768: N3348 G21
    Recv:17:44:19.771: ok (N3348)
    Send:17:44:19.771: N3349 G21
    Recv:17:44:19.774: ok (N3349)
    Send:17:44:19.774: N3350 G21
    Recv:17:44:19.777: ok (N3350)
    Send:17:44:19.777: N3351 G21
    Recv:17:44:19.779: ok (N3351)
    Send:17:44:19.779: N3352 G21
    Recv:17:44:19.782: ok (N3352)
    Send:17:44:19.782: N3353 G21
    Recv:17:44:19.785: ok (N3353)
    Send:17:44:19.785: N3354 G21
    Recv:17:44:19.788: ok (N3354)
    Send:17:44:19.788: N3355 G21
    Recv:17:44:19.791: ok (N3355)
    Send:17:44:19.791: N3356 G21
    Recv:17:44:19.794: ok (N3356)
    Send:17:44:19.794: N3357 G21
    Recv:17:44:19.797: ok (N3357)
    Send:17:44:19.797: N3358 G21
    Recv:17:44:19.800: ok (N3358)
    Send:17:44:19.800: N3359 G21
    Recv:17:44:19.802: ok (N3359)
    Send:17:44:19.802: N3360 G21
    Recv:17:44:19.805: ok (N3360)
    Send:17:44:19.805: N3361 G21
    Recv:17:44:19.808: ok (N3361)
    Send:17:44:19.808: N3362 G21
    Recv:17:44:19.811: ok (N3362)
    Send:17:44:19.811: N3363 G21
    Recv:17:44:19.814: ok (N3363)
    Send:17:44:19.814: N3364 G21
    Recv:17:44:19.818: ok (N3364)
    Send:17:44:19.818: N3365 G21
    Recv:17:44:19.821: ok (N3365)
    Send:17:44:19.821: N3366 G21
    Recv:17:44:19.824: ok (N3366)
    Send:17:44:19.824: N3367 G21
    Recv:17:44:19.827: ok (N3367)
    Send:17:44:19.827: N3368 G21
    Recv:17:44:19.830: ok (N3368)
    Send:17:44:19.830: N3369 G21
    Recv:17:44:19.833: ok (N3369)
    Send:17:44:19.833: N3370 G21
    Recv:17:44:19.835: ok (N3370)
    Send:17:44:19.835: N3371 G21
    Recv:17:44:19.838: ok (N3371)
    Send:17:44:19.838: N3372 G21
    Recv:17:44:19.841: ok (N3372)
    Send:17:44:19.841: N3373 G21
    Recv:17:44:19.844: ok (N3373)
    Send:17:44:19.844: N3374 G21
    Recv:17:44:19.847: ok (N3374)
    Send:17:44:19.847: N3375 G21
    Recv:17:44:19.850: ok (N3375)
    Send:17:44:19.850: N3376 G21
    Recv:17:44:19.853: ok (N3376)
    Send:17:44:19.853: N3377 G21
    Recv:17:44:19.856: ok (N3377)
    Send:17:44:19.856: N3378 G21
    Recv:17:44:19.859: ok (N3378)
    Send:17:44:19.859: N3379 G21
    Recv:17:44:19.862: ok (N3379)
    Send:17:44:19.862: N3380 G21
    Recv:17:44:19.865: ok (N3380)
    Send:17:44:19.865: N3381 G21
    Recv:17:44:19.868: ok (N3381)
    Send:17:44:19.868: N3382 G21
    Recv:17:44:19.871: ok (N3382)
    Send:17:44:19.871: N3383 G21
    Recv:17:44:19.874: ok (N3383)
    Send:17:44:19.874: N3384 G21
    Recv:17:44:19.877: ok (N3384)
    Send:17:44:19.877: N3385 G21
    Recv:17:44:19.880: ok (N3385)
    Send:17:44:19.880: N3386 G21
    Recv:17:44:19.883: ok (N3386)
    Send:17:44:19.883: N3387 G21
    Recv:17:44:19.886: ok (N3387)
    Send:17:44:19.886: N3388 G21
    Recv:17:44:19.889: ok (N3388)
    Send:17:44:19.889: N3389 G21
    Recv:17:44:19.892: ok (N3389)
    Send:17:44:19.892: N3390 G21
    Recv:17:44:19.895: ok (N3390)
    Send:17:44:19.895: N3391 G21
    Recv:17:44:19.897: ok (N3391)
    Send:17:44:19.897: N3392 G21
    Recv:17:44:19.900: ok (N3392)
    Send:17:44:19.900: N3393 G21
    Recv:17:44:19.903: ok (N3393)
    Send:17:44:19.903: N3394 G21
    Recv:17:44:19.906: ok (N3394)
    Send:17:44:19.906: N3395 G21
    Recv:17:44:19.909: ok (N3395)
    Send:17:44:19.909: N3396 G21
    Recv:17:44:19.912: ok (N3396)
    Send:17:44:19.912: N3397 G21
    Recv:17:44:19.915: ok (N3397)
    Send:17:44:19.915: N3398 G21
    Recv:17:44:19.918: ok (N3398)
    Send:17:44:19.918: N3399 G21
    Recv:17:44:19.921: ok (N3399)
    Send:17:44:19.921: N3400 G21
    Recv:17:44:19.924: ok (N3400)
    Send:17:44:19.924: N3401 G21
    Recv:17:44:19.927: ok (N3401)
    Send:17:44:19.927: N3402 G21
    Recv:17:44:19.930: ok (N3402)
    Send:17:44:19.930: N3403 G21
    Recv:17:44:19.932: ok (N3403)
    Send:17:44:19.933: N3404 G21
    Recv:17:44:19.935: ok (N3404)
    Send:17:44:19.936: N3405 G21
    Recv:17:44:19.938: ok (N3405)
    Send:17:44:19.938: N3406 G21
    Recv:17:44:19.941: ok (N3406)
    Send:17:44:19.941: N3407 G21
    Recv:17:44:19.944: ok (N3407)
    Send:17:44:19.944: N3408 G21
    Recv:17:44:19.947: ok (N3408)
    Send:17:44:19.947: N3409 G21
    Recv:17:44:19.950: ok (N3409)
    Send:17:44:19.950: N3410 G21
    Recv:17:44:19.954: ok (N3410)
    Send:17:44:19.954: N3411 G21
    Recv:17:44:19.956: ok (N3411)
    Send:17:44:19.956: N3412 G21
    Recv:17:44:19.959: ok (N3412)
    Send:17:44:19.959: N3413 G21
    Recv:17:44:19.962: ok (N3413)
    Send:17:44:19.962: N3414 G21
    Recv:17:44:19.965: ok (N3414)
    Send:17:44:19.965: N3415 G21
    Recv:17:44:19.968: ok (N3415)
    Send:17:44:19.968: N3416 G21
    Recv:17:44:19.971: ok (N3416)
    Send:17:44:19.971: N3417 G21
    Recv:17:44:19.975: ok (N3417)
    Send:17:44:19.975: N3418 G21
    Recv:17:44:19.977: ok (N3418)
    Send:17:44:19.977: N3419 G21
    Recv:17:44:19.980: ok (N3419)
    Send:17:44:19.980: N3420 G21
    Recv:17:44:19.983: ok (N3420)
    Send:17:44:19.983: N3421 G21
    Recv:17:44:19.986: ok (N3421)
    Send:17:44:19.986: N3422 G21
    Recv:17:44:19.989: ok (N3422)
    Send:17:44:19.989: N3423 G21
    Recv:17:44:19.992: ok (N3423)
    Send:17:44:19.992: N3424 G21
    Recv:17:44:19.995: ok (N3424)
    Send:17:44:19.995: N3425 G21
    Recv:17:44:19.998: ok (N3425)
    Send:17:44:19.998: N3426 G21
    Recv:17:44:20.001: ok (N3426)
    Send:17:44:20.001: N3427 G21
    Recv:17:44:20.003: ok (N3427)
    Send:17:44:20.004: N3428 G21
    Recv:17:44:20.007: ok (N3428)
    Send:17:44:20.007: N3429 G21
    Recv:17:44:20.010: ok (N3429)
    Send:17:44:20.010: N3430 G21
    Recv:17:44:20.013: ok (N3430)
    Send:17:44:20.013: N3431 G21
    Recv:17:44:20.016: ok (N3431)
    Send:17:44:20.016: N3432 G21
    Recv:17:44:20.019: ok (N3432)
    Send:17:44:20.019: N3433 G21
    Recv:17:44:20.022: ok (N3433)
    Send:17:44:20.022: N3434 G21
    Recv:17:44:20.025: ok (N3434)
    Send:17:44:20.025: N3435 G21
    Recv:17:44:20.028: ok (N3435)
    Send:17:44:20.028: N3436 G21
    Recv:17:44:20.031: ok (N3436)
    Send:17:44:20.031: N3437 G21
    Recv:17:44:20.034: ok (N3437)
    Send:17:44:20.034: N3438 G21
    Recv:17:44:20.037: ok (N3438)
    Send:17:44:20.037: N3439 G21
    Recv:17:44:20.040: ok (N3439)
    Send:17:44:20.040: N3440 G21
    Recv:17:44:20.043: ok (N3440)
    Send:17:44:20.043: N3441 G21
    Recv:17:44:20.045: ok (N3441)
    Send:17:44:20.045: N3442 G21
    Recv:17:44:20.049: ok (N3442)
    Send:17:44:20.049: N3443 G21
    Recv:17:44:20.052: ok (N3443)
    Send:17:44:20.052: N3444 G21
    Recv:17:44:20.055: ok (N3444)
    Send:17:44:20.056: N3445 G21
    Recv:17:44:20.059: ok (N3445)
    Send:17:44:20.059: N3446 G21
    Recv:17:44:20.062: ok (N3446)
    Send:17:44:20.063: N3447 G21
    Recv:17:44:20.066: ok (N3447)
    Send:17:44:20.066: N3448 G21
    Recv:17:44:20.069: ok (N3448)
    Send:17:44:20.069: N3449 G21
    Recv:17:44:20.072: ok (N3449)
    Send:17:44:20.072: N3450 G21
    Recv:17:44:20.076: ok (N3450)
    Send:17:44:20.076: N3451 G21
    Recv:17:44:20.080: ok (N3451)
    Send:17:44:20.080: N3452 G21
    Recv:17:44:20.083: ok (N3452)
    Send:17:44:20.083: N3453 G21
    Recv:17:44:20.086: ok (N3453)
    Send:17:44:20.086: N3454 G21
    Recv:17:44:20.089: ok (N3454)
    Send:17:44:20.089: N3455 G21
    Recv:17:44:20.092: ok (N3455)
    Send:17:44:20.092: N3456 G21
    Recv:17:44:20.095: ok (N3456)
    Send:17:44:20.095: N3457 G21
    Recv:17:44:20.098: ok (N3457)
    Send:17:44:20.098: N3458 G21
    Recv:17:44:20.101: ok (N3458)
    Send:17:44:20.101: N3459 G21
    Recv:17:44:20.104: ok (N3459)
    Send:17:44:20.104: N3460 G21
    Recv:17:44:20.107: ok (N3460)
    Send:17:44:20.107: N3461 G21
    Recv:17:44:20.110: ok (N3461)
    Send:17:44:20.110: N3462 G21
    Recv:17:44:20.113: ok (N3462)
    Send:17:44:20.113: N3463 G21
    Recv:17:44:20.117: ok (N3463)
    Send:17:44:20.117: N3464 G21
    Recv:17:44:20.120: ok (N3464)
    Send:17:44:20.120: N3465 G21
    Recv:17:44:20.122: ok (N3465)
    Send:17:44:20.122: N3466 G21
    Recv:17:44:20.126: ok (N3466)
    Send:17:44:20.126: N3467 G21
    Recv:17:44:20.129: ok (N3467)
    Send:17:44:20.129: N3468 G21
    Recv:17:44:20.132: ok (N3468)
    Send:17:44:20.132: N3469 G21
    Recv:17:44:20.135: ok (N3469)
    Send:17:44:20.135: N3470 G21
    Recv:17:44:20.138: ok (N3470)
    Send:17:44:20.138: N3471 G21
    Recv:17:44:20.141: ok (N3471)
    Send:17:44:20.141: N3472 G21
    Recv:17:44:20.144: ok (N3472)
    Send:17:44:20.144: N3473 G21
    Recv:17:44:20.146: ok (N3473)
    Send:17:44:20.147: N3474 G21
    Recv:17:44:20.149: ok (N3474)
    Send:17:44:20.149: N3475 G21
    Recv:17:44:20.152: ok (N3475)
    Send:17:44:20.152: N3476 G21
    Recv:17:44:20.156: ok (N3476)
    Send:17:44:20.156: N3477 G21
    Recv:17:44:20.159: ok (N3477)
    Send:17:44:20.159: N3478 G21
    Recv:17:44:20.161: ok (N3478)
    Send:17:44:20.161: N3479 G21
    Recv:17:44:20.165: ok (N3479)
    Send:17:44:20.165: N3480 G21
    Recv:17:44:20.168: ok (N3480)
    Send:17:44:20.168: N3481 G21
    Recv:17:44:20.171: ok (N3481)
    Send:17:44:20.171: N3482 G21
    Recv:17:44:20.174: ok (N3482)
    Send:17:44:20.174: N3483 G21
    Recv:17:44:20.177: ok (N3483)
    Send:17:44:20.177: N3484 G21
    Recv:17:44:20.180: ok (N3484)
    Send:17:44:20.180: N3485 G21
    Recv:17:44:20.183: ok (N3485)
    Send:17:44:20.183: N3486 G21
    Recv:17:44:20.186: ok (N3486)
    Send:17:44:20.186: N3487 G21
    Recv:17:44:20.188: ok (N3487)
    Send:17:44:20.189: N3488 G21
    Recv:17:44:20.191: ok (N3488)
    Send:17:44:20.191: N3489 G21
    Recv:17:44:20.194: ok (N3489)
    Send:17:44:20.194: N3490 G21
    Recv:17:44:20.197: ok (N3490)
    Send:17:44:20.197: N3491 G21
    Recv:17:44:20.200: ok (N3491)
    Send:17:44:20.200: N3492 G21
    Recv:17:44:20.203: ok (N3492)
    Send:17:44:20.203: N3493 G21
    Recv:17:44:20.207: ok (N3493)
    Send:17:44:20.207: N3494 G21
    Recv:17:44:20.210: ok (N3494)
    Send:17:44:20.210: N3495 G21
    Recv:17:44:20.214: ok (N3495)
    Send:17:44:20.214: N3496 G21
    Recv:17:44:20.218: ok (N3496)
    Send:17:44:20.218: N3497 G21
    Recv:17:44:20.222: ok (N3497)
    Send:17:44:20.222: N3498 G21
    Recv:17:44:20.225: ok (N3498)
    Send:17:44:20.225: N3499 G21
    Recv:17:44:20.228: ok (N3499)
    Send:17:44:20.228: N3500 G21
    Recv:17:44:20.231: ok (N3500)
    Send:17:44:20.231: N3501 G21
    Recv:17:44:20.234: ok (N3501)
    Send:17:44:20.234: N3502 G21
    Recv:17:44:20.237: ok (N3502)
    Send:17:44:20.237: N3503 G21
    Recv:17:44:20.240: ok (N3503)
    Send:17:44:20.240: N3504 G21
    Recv:17:44:20.244: ok (N3504)
    Send:17:44:20.244: N3505 G21
    Recv:17:44:20.247: ok (N3505)
    Send:17:44:20.247: N3506 G21
    Recv:17:44:20.250: ok (N3506)
    Send:17:44:20.250: N3507 G21
    Recv:17:44:20.253: ok (N3507)
    Send:17:44:20.253: N3508 G21
    Recv:17:44:20.255: ok (N3508)
    Send:17:44:20.255: N3509 G21
    Recv:17:44:20.258: ok (N3509)
    Send:17:44:20.258: N3510 G21
    Recv:17:44:20.261: ok (N3510)
    Send:17:44:20.261: N3511 G21
    Recv:17:44:20.264: ok (N3511)
    Send:17:44:20.264: N3512 G21
    Recv:17:44:20.267: ok (N3512)
    Send:17:44:20.267: N3513 G21
    Recv:17:44:20.270: ok (N3513)
    Send:17:44:20.270: N3514 G21
    Recv:17:44:20.273: ok (N3514)
    Send:17:44:20.273: N3515 G21
    Recv:17:44:20.276: ok (N3515)
    Send:17:44:20.276: N3516 G21
    Recv:17:44:20.280: ok (N3516)
    Send:17:44:20.280: N3517 G21
    Recv:17:44:20.283: ok (N3517)
    Send:17:44:20.283: N3518 G21
    Recv:17:44:20.286: ok (N3518)
    Send:17:44:20.286: N3519 G21
    Recv:17:44:20.289: ok (N3519)
    Send:17:44:20.289: N3520 G21
    Recv:17:44:20.291: ok (N3520)
    Send:17:44:20.291: N3521 G21
    Recv:17:44:20.294: ok (N3521)
    Send:17:44:20.294: N3522 G21
    Recv:17:44:20.297: ok (N3522)
    Send:17:44:20.297: N3523 G21
    Recv:17:44:20.303: ok (N3523)
    Send:17:44:20.303: N3524 G21
    Recv:17:44:20.310: ok (N3524)
    Send:17:44:20.310: N3525 G21
    Recv:17:44:20.313: ok (N3525)
    Send:17:44:20.313: N3526 G21
    Recv:17:44:20.316: ok (N3526)
    Send:17:44:20.316: N3527 G21
    Recv:17:44:20.319: ok (N3527)
    Send:17:44:20.319: N3528 G21
    Recv:17:44:20.322: ok (N3528)
    Send:17:44:20.322: N3529 G21
    Recv:17:44:20.325: ok (N3529)
    Send:17:44:20.325: N3530 G21
    Recv:17:44:20.328: ok (N3530)
    Send:17:44:20.328: N3531 M77
    Recv:17:44:20.331: ok (N3531)
    Send:17:44:20.331: Slow command added:G4 S20
    Send:17:44:20.331: N3532 G4 S20
  • Hast du zuletzt einen Kommunikationstest laufen lassen? Da können die G21 herkommen.
    Ansonsten G4 zeight kein busy, scheint also alter Marlin Version zu sein oder das Feature wurde deaktiviert. In dem Fall muss das timeout länger als die langsamste Bewegung sein, sonst kann es dort zu timeouts kommen.
    Aber Drucken mit logging ist schon mal gut, dann siehst du wenn es wieder passiert wie es entsteht bzw. was es auslöst.
  • Danke für die schnelle Rückmeldung.
    Ich habe den Druck gestern Abend nach 4 Stunden abgebrochen da ich nicht wollte dass der Drucker sich über Nacht  eventuell aufhängt...
    Am Wochenende mache ich noch einmal einen neuen Test.
    Kann man sich das irgendwie ausrechnen welche Timeouts man einstellen sollte?
    Die Marlin Version ist vom Februar 2023.
    Das Busy Protocol kann man vermutlich nur beim neukompilieren der Firmware aktiveren oder?
    Vielen Dank!
    Hier die Ausgabe wenn ich die Maschine starte gefolgt von einem M501 Befehl:
    Mesg:9:58:10.438: Connection started
    Mesg:9:58:10.438: Printer reset requested - emergency:false
    Mesg:9:58:10.439: Dtr: false Rts: false
    Mesg:9:58:10.468: Dtr: true Rts: true
    Recv:9:58:13.484: Send init commands because we had no signal from a reset, assuming reset not available.
    Send:9:58:13.484: N1 M110
    Recv:9:58:13.923: Response while unconnected:u16Cycle: 43032
    Recv:9:58:13.923: u16Cycle: 43032
    Recv:9:58:14.181: Response while unconnected:============SETUP FINISH============
    Recv:9:58:14.181: ============SETUP FINISH============
    Recv:9:58:14.690: Response while unconnected:echo:SD card ok
    Recv:9:58:14.690: echo:SD card ok
    Recv:9:58:14.695: Response while unconnected:Bilinear Leveling Grid:
    Recv:9:58:14.695: Bilinear Leveling Grid:
    Recv:9:58:14.698: Response while unconnected:0 1 2 3 4
    Recv:9:58:14.698: 0 1 2 3 4
    Recv:9:58:14.705: Response while unconnected:0 -3.361 -2.614 -2.326 -2.323 -2.415
    Recv:9:58:14.705: 0 -3.361 -2.614 -2.326 -2.323 -2.415
    Recv:9:58:14.708: Response while unconnected:1 -2.590 -2.001 -1.729 -1.921 -2.201
    Recv:9:58:14.708: 1 -2.590 -2.001 -1.729 -1.921 -2.201
    Recv:9:58:14.711: Response while unconnected:2 -2.474 -1.872 -1.642 -1.969 -2.493
    Recv:9:58:14.711: 2 -2.474 -1.872 -1.642 -1.969 -2.493
    Recv:9:58:14.714: Response while unconnected:3 -2.642 -2.118 -2.021 -2.366 -2.810
    Recv:9:58:14.714: 3 -2.642 -2.118 -2.021 -2.366 -2.810
    Recv:9:58:14.717: Response while unconnected:4 -3.420 -2.926 -2.882 -3.127 -3.487
    Recv:9:58:14.717: 4 -3.420 -2.926 -2.882 -3.127 -3.487
    Recv:9:58:14.720: Response while unconnected:echo:Bed Leveling ON
    Recv:9:58:14.720: echo:Bed Leveling ON
    Recv:9:58:14.723: Response while unconnected:echo:Fade Height OFF
    Recv:9:58:14.723: echo:Fade Height OFF
    Recv:9:58:14.726: Response while unconnected:X:-6.20 Y:-20.50 Z:3.36 E:0.00 Count X:-496 Y:-1640 Z:0
    Recv:9:58:14.726: X:-6.20 Y:-20.50 Z:3.36 E:0.00 Count X:-496 Y:-1640 Z:0
    Recv:9:58:14.726: Connection verified by:ok
    Recv:9:58:14.726: ok (N1)
    Recv:9:58:14.728: ok (N2)
    Send:9:58:14.742: N4 M115 ; Get firmware capabilities and info
    Send:9:58:14.751: N5 M220 S100 ; Speed multiplier 100%
    Recv:9:58:14.768: FIRMWARE_NAME:Marlin bugfix-2.0.x (Feb 17 2023 10:30:27) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Anycubic Viper EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
    Recv:9:58:14.771: Cap:SERIAL_XON_XOFF:0
    Recv:9:58:14.775: Cap:BINARY_FILE_TRANSFER:0
    Recv:9:58:14.775: Cap:EEPROM:1
    Recv:9:58:14.778: Cap:VOLUMETRIC:1
    Recv:9:58:14.781: Cap:AUTOREPORT_TEMP:1
    Recv:9:58:14.781: Cap:PROGRESS:0
    Recv:9:58:14.784: Cap:PRINT_JOB:1
    Recv:9:58:14.784: Cap:AUTOLEVEL:1
    Recv:9:58:14.787: Cap:RUNOUT:1
    Recv:9:58:14.787: Cap:Z_PROBE:1
    Recv:9:58:14.790: Cap:LEVELING_DATA:1
    Recv:9:58:14.793: Cap:BUILD_PERCENT:0
    Recv:9:58:14.793: Cap:SOFTWARE_POWER:0
    Recv:9:58:14.796: Cap:TOGGLE_LIGHTS:1
    Recv:9:58:14.800: Cap:CASE_LIGHT_BRIGHTNESS:0
    Recv:9:58:14.803: Cap:EMERGENCY_PARSER:1
    Recv:9:58:14.803: Cap:PROMPT_SUPPORT:0
    Recv:9:58:14.806: Cap:SDCARD:1
    Recv:9:58:14.806: Cap:REPEAT:1
    Recv:9:58:14.809: Cap:AUTOREPORT_SD_STATUS:0
    Recv:9:58:14.812: Cap:LONG_FILENAME:1
    Recv:9:58:14.812: Cap:THERMAL_PROTECTION:1
    Recv:9:58:14.815: Cap:MOTION_MODES:0
    Recv:9:58:14.815: Cap:ARCS:1
    Recv:9:58:14.818: Cap:BABYSTEPPING:1
    Recv:9:58:14.821: Cap:CHAMBER_TEMPERATURE:0
    Recv:9:58:14.821: ok (N5)
    Mesg:9:58:14.821: Received extra ok - ignored
    Send:9:58:14.821: N6 M221 S100 ; Flow multiplier 100%
    Recv:9:58:14.824: ok (N6)
    Send:9:58:14.824: N7 G92 E0
    Recv:9:58:14.833: X:-6.20 Y:-20.50 Z:3.36 E:0.00 Count X:-496 Y:-1640 Z:0
    Recv:9:58:14.833: ok (N7)
    Send:9:58:14.833: N8 G90
    Recv:9:58:14.835: ok (N8)
    Send:9:58:14.835: N9 M82
    Recv:9:58:14.838: ok (N9)
    Send:9:58:14.838: N10 G21 ; Use mm as unit
    Recv:9:58:14.841: ok (N10)
    Send:9:58:14.841: N11 M114
    Recv:9:58:14.849: X:-6.20 Y:-20.50 Z:3.36 E:0.00 Count X:-496 Y:-1640 Z:0
    Recv:9:58:14.849: ok (N11)
    Exec:9:58:14.849: @getIP
    Send:9:58:14.857: N12 M114
    Recv:9:58:14.866: X:-6.20 Y:-20.50 Z:3.36 E:0.00 Count X:-496 Y:-1640 Z:0
    Recv:9:58:14.866: ok (N12)
    Exec:9:58:14.866: @startCodeProcessed
    Send:9:58:14.866: N13 M155 S1
    Recv:9:58:14.869: ok (N13)
    Send:9:58:14.869: M117 192.168.4.1:3344
    Recv:9:58:14.872: ok
    Exec:9:58:25.472: @getip
    Send:9:58:25.479: M117 192.168.4.1:3344
    Recv:9:58:25.482: ok
    Recv:10:04:20.890: DIGIPOTS Loading
    Recv:10:04:20.891: DIGIPOTS Loaded
    Recv:10:04:20.895: DIGIPOTS Loading
    Recv:10:04:20.898: DIGIPOTS Loaded
    Recv:10:04:20.901: echo:V82 stored settings retrieved (770 bytes; crc 15138)
    Recv:10:04:20.904: echo: G21 ; Units in mm (mm)
    Recv:10:04:20.907: echo:; Filament settings: Disabled
    Recv:10:04:20.910: echo: M200 S0 D1.75
    Recv:10:04:20.913: echo:; Steps per unit:
    Recv:10:04:20.916: echo: M92 X80.00 Y80.00 Z400.00 E409.87
    Recv:10:04:20.919: echo:; Maximum feedrates (units/s):
    Recv:10:04:20.925: echo: M203 X300.00 Y300.00 Z40.00 E60.00
    Recv:10:04:20.929: echo:; Maximum Acceleration (units/s2):
    Recv:10:04:20.932: echo: M201 X700.00 Y600.00 Z100.00 E3000.00
    Recv:10:04:20.941: echo:; Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
    Recv:10:04:20.944: echo: M204 P1500.00 R1000.00 T1500.00
    Recv:10:04:20.957: echo:; Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>
    Recv:10:04:20.964: echo: M205 B20000.00 S0.00 T0.00 X5.00 Y5.00 Z0.30 E5.00
    Recv:10:04:20.966: echo:; Home offset:
    Recv:10:04:20.970: echo: M206 X0.00 Y0.00 Z0.00
    Recv:10:04:20.970: echo:; Auto Bed Leveling:
    Recv:10:04:20.973: echo: M420 S0 Z0.00
    Recv:10:04:20.976: echo: G29 W I0 J0 Z-3.36100
    Recv:10:04:20.978: echo: G29 W I1 J0 Z-2.61400
    Recv:10:04:20.982: echo: G29 W I2 J0 Z-2.32600
    Recv:10:04:20.985: echo: G29 W I3 J0 Z-2.32300
    Recv:10:04:20.988: echo: G29 W I4 J0 Z-2.41500
    Recv:10:04:20.988: echo: G29 W I0 J1 Z-2.58950
    Recv:10:04:20.991: echo: G29 W I1 J1 Z-2.00100
    Recv:10:04:20.994: echo: G29 W I2 J1 Z-1.72900
    Recv:10:04:20.997: echo: G29 W I3 J1 Z-1.92050
    Recv:10:04:21.000: echo: G29 W I4 J1 Z-2.20050
    Recv:10:04:21.003: echo: G29 W I0 J2 Z-2.47450
    Recv:10:04:21.007: echo: G29 W I1 J2 Z-1.87150
    Recv:10:04:21.010: echo: G29 W I2 J2 Z-1.64200
    Recv:10:04:21.013: echo: G29 W I3 J2 Z-1.96900
    Recv:10:04:21.017: echo: G29 W I4 J2 Z-2.49350
    Recv:10:04:21.017: echo: G29 W I0 J3 Z-2.64150
    Recv:10:04:21.020: echo: G29 W I1 J3 Z-2.11750
    Recv:10:04:21.023: echo: G29 W I2 J3 Z-2.02050
    Recv:10:04:21.026: echo: G29 W I3 J3 Z-2.36650
    Recv:10:04:21.029: echo: G29 W I4 J3 Z-2.81000
    Recv:10:04:21.032: echo: G29 W I0 J4 Z-3.42000
    Recv:10:04:21.035: echo: G29 W I1 J4 Z-2.92600
    Recv:10:04:21.039: echo: G29 W I2 J4 Z-2.88150
    Recv:10:04:21.041: echo: G29 W I3 J4 Z-3.12700
    Recv:10:04:21.044: echo: G29 W I4 J4 Z-3.48700
    Recv:10:04:21.044: echo:; PID settings:
    Recv:10:04:21.047: echo: M301 P36.51 I5.34 D62.42
    Recv:10:04:21.051: echo: M304 P137.63 I15.40 D819.80
    Recv:10:04:21.054: ; Controller Fan
    Recv:10:04:21.057: echo: M710 S255 I0 A1 D60 ; (100% 0%)
    Recv:10:04:21.060: echo:; Power-Loss Recovery:
    Recv:10:04:21.060: echo: M413 S1
    Recv:10:04:21.063: echo:; Z-Probe Offset (mm):
    Recv:10:04:21.066: echo: M851 X0 Y0 Z0.15
    Recv:10:04:21.069: echo:; Filament load/unload lengths:
    Recv:10:04:21.072: echo: M603 L0.00 U100.00
    Recv:10:04:21.076: echo:; Filament runout sensor:
    Recv:10:04:21.077: echo: M412 S1
  • Ja busy ist eine config option bei Marlin. Wenn es aktiv ist kann timeout auf 3s reduziert werden. Ansonsten brauchst du max(SegmenlängeInMM/GeschwindigkeitInMMProS) für alle Bewegungen. Im Zweifelsfall druckbett diagonale/langsamste geschwindigkeit. Wobei Z nicht vergessen werden darf wo oft anderes maximum vorliegt.
  • Vielen Dank,
    Der Kobra Max hat ja eine Druckbett-Diagonale von 402x402x452 (LxBxH).
    Die niedrigste Geschwindigkeit die ich habe ist beim First Layer mit 20mm/s, das würde dann bedeuten dass ich so rechnen muss: 402/20 = 20,1
    Aber was hat das mit der Z-Achse zu tun bzw. wie kann ich die in die Rechnung mit einbeziehen?
    Danke
  • Diagonale ist 1.41 mal, also 28.2s.
    Wenn z maximalgeschwindigkeit 10mm/s brauchst du von oben nach untern 452/10 = 45.2s. Ist aber eher selten und vielleicht kann er ja auch schneller.
  • Ok sorry bin gerade etwas verwirrt..
    Sollte ich jetzt 45 Sekunden beim Timeout einstellen?
    Hab die Zeit gestoppt beim runterfahren der Z Achse und es waren genau 45,12 Sekunden :)
  • Dann hab ich ja gut geraten:-) Theoretisch ist das der richtige wert aber andererseits soll er möglichst kurz sein. Würde also normal trotzdem 30s nehmen auch wenn evtl. ein Timeout bei dem move passiert. Es sollte dir nur klar sein das es wegen der langsamen Bewegung so sein kann. Wenn es der letzte ist passiert trotzdem nicht.
  • ah ok danke verstehe!
    Dann nehme ich mal 30 Sekunden :)
    Vielen Dank!
  • edited December 2023
    Die letzen beiden längeren Drucke haben einwandfrei funktioniert.
    Nochmals Danke!
