I think in the latest Version 1.4.14 the Temperatur Graph shows the PWM Power instead of Percent of the Power for the Extruder. the Bed Temperature looks ok.
For which firmware/ connection method do you get this?
Why do you think this? Not aware of any changes and testing Klipper and Marlin visualization they look ok. But some combinations have special solution or a firmware setting might be wrong so there might exist a combo with an error. E.g. Marlin outputs power 0-127 and we multiply it to scale. If you have marlin on firmware that does not reduce range you get 0-200% instead. Knowing the combo I will have a closer look at it.
No screenshot upload, sorry. Only with external services like imgur.com or from your cloud drive if you make the file public.
Klipper is new - it did not have output at all before only since we added api connection. Will check again my klipper to see if I oversaw something. I assume you connected using our klipper solution with klipper firmware selected.
Thanks. I looked at the graph and there it was clipped at 100% so not visible. Could see where it got scaled wrong. Fixed in dev version and will be in next official release.
https://imgur.com/a/DUUiS6X
when I can help with aditional data or Logs please let me know
installDev
to get it already.
