config files
Windows 10
RH 1.5.6
where can I find the config files so I can copy them to another computer?
thx
  • They are in you work directory (See files menu) and in registry (HKEY_CURRENT_USER/Software/RepetierHost)
  • i found them here
    HKEY_CURRENT_USER\SOFTWARE\Repetier\printer
    but there is nothing related in the work folder - only the slic3r ini file which isn't useful since I copy the slic3r folder.
    so the answer is I need to export/import the reg entries.
    easy enough I guess.
    thx
  • Slicer stores it settings in homedir/AppData/Roaming/Slic3r
    In workdir there should have a CuraEngine folder with curaengine settings if you used/created them.
