GPIO Access
Is the GPIO access only in Repetier Server. Have a print farm and want to have each installation of RH switch GPIO pins to turn off a power relay to automatically turn the printer on and off. Problem is that Pro Server (or any Repetier Server) cant interface with Server installations for indivisial printers only host installations.
For pro zou can use Repetier-Server Monitor to manage all servers in one interface.
But I'm not sure what your problem is - when you can access the printer you can send commands and change it's gpio pins. What do you want from other servers in that context?
