Update gcode while printing
Would love the ability to update a print mid-print! Who hasn't started a print and then realized they used too much or too little infill?. Currently we are having to stop and start over when often it would be sufficient to run updated gcode from the next layer onwards. What do you think?
- file name of running print = filename of new (updated) gcode file
- number of objects is 1 on both files,
- number of layers is identical in both files,
- max-Z is the same in both files
Finally we could have a warning popup when someone does click the 'update running print' buttonBut I get it, it might not be possible to reliably pick up a layer change, specially when lift-z is enabled and/or a purge tower is used and potentially a ton of other things that could affect it. But thanks anyway for commenting this morning.
