Controlling Native Klipper Printers
Hi, I am looking at picking up some of the newer printers that run klipper natively, such as the Creality K1 or K1 max. Is this a problem for repetier-server to control a printer that has klipper natively installed? I already am using it to control a few Vorons but the version of klipper on those is the integrated into repetier-server. The newer klipper printers have klipper already running on them and repetier-server would be running on a separate computer.
A connection to mainsail which is most likely running on the creality if it uses klipper is currently not possible.
sudo systemctl daemon-reload
it should run as that use on next restart.
