Slic3r don't write start g-code in repetier
I have update slic3r to Repetier Host  and now when I try to slice any object the start g-code goes wrong like slic3r won't read the custom gcode from my profiles.
If I slice the file into slic3r software the gcode output is correct, but if i slice the file with slic3r through Repetier Host 1.5.6 the start g-code missing or there is oly a G28 and M104..
Repetier Host scripts are empty....
What I'm doing wrong?
Thank you
  • Are you using th esame printer profile like when using it in slic3r directly? Since it is part of the printer configuration you need the right one.
