Linux Repetier-Server with Klipper
I want to setup a single dedicated NUC i7 /Linux Repetier-Server with Klipper to control 10 printers. Don't want a bunch of Pi's.
Is this doable and practical?
If so. Any advice on the install and setup?
Most challenging is normally the amount of usb connections and emf, but others have simliar amount of printers running from a pc so it is possible. Just note that if you have also webcams on it bandwidth (on usb) can get a factor, so best connect them to a different independent usb line then printers so there is no interference.
