Feature Request: Enhanced Temperature Info for Testing
Tonight I was trying out various materials for under bed insulation, just to see if I could improve the heat up times. I had 6mm cork sheets, 3mm Auto Sun Shield Mylar, Adhesive Fiberglass Tape, and a Zoltek Pyron heat shield.
I could not really see differences very well, and then I realized that what I really needed was the second derivative of the temperature info.  So my request is for either adding 2nd Derivative to the graphing output, or at least have a means of exporting the graph data to CSV.
Thanks.
  • We even haven't a 1st derivative and you need the second? I do not think that is what users really want, except maybe some experts with special needs. So we will not add this.
    You can easily make a plugin for this. You can tell the host to report all firmware responses and filter and write all lines to a file for example, or even parse it and write it including derivatives to file. It's just a few lines to the demo plugin and removing the demo tab code.
