I can't install Klipper
I want to install Klipper on my server
I'm going to load a printer, I select the Klipper firmware and the button to install Klipper appears, I press it, it starts to install but it freezes.
Reinstall my Raspberry image and try again but still the same
Resolving download1.repetier.com (download1.repetier.com)... 94.130.164.39
Connecting to download1.repetier.com (download1.repetier.com)|94.130.164.39|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5833 (5.7K) [application/octet-stream]
Saving to: '/tmp/klipperInstaller.sh'
/tmp/klipperInstaller. 100%[============================>]   5.70K  --.-KB/s    in 0s
2023-04-25 23:32:00 (146 MB/s) - '/tmp/klipperInstaller.sh' saved [5833/5833]
Install klipper with parameter: Klipper1 tags/v0.10.0 1 https://github.com/Klipper3d/klipper.git
Shell: /bin/bash
###### Running apt-get update ######
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:3 https://pkg.duet3d.com stable InRelease
Reading package lists... Done
###### Installing packages ######
Building dependency tree... Done
Reading state information... Done
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
git is already the newest version (1:2.30.2-1+deb11u2).
libusb-1.0-0 is already the newest version (2:1.0.24-3).
libusb-1.0-0 set to manually installed.
The following packages were automatically installed and are no longer required:
  dc raspinfo
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  dpkg-dev fakeroot g++-10 gcc gcc-10 libalgorithm-diff-perl libalgorithm-diff-xs-perl
  libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot libftdi1 libgcc-10-dev
  libhidapi-libusb0 libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
  libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libstdc++-10-dev
  libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 make python2 python2-minimal
  python2.7 python2.7-dev python2.7-minimal python3-appdirs python3-distlib
  python3-filelock python3-importlib-metadata python3-more-itertools python3-virtualenv
  python3-zipp
Suggested packages:
  dfu-programmer avrdude-doc debian-keyring gcc-10-doc gcc-multilib autoconf automake
  libtool flex bison gcc-doc gcc-10-locales ncurses-doc libnewlib-doc libstdc++-10-doc
  make-doc python2-doc python-tk python2.7-doc binfmt-support
The following NEW packages will be installed:
  avr-libc avrdude binutils-arm-none-eabi binutils-avr build-essential dfu-util dpkg-dev
  fakeroot g++ g++-10 gcc gcc-10 gcc-arm-none-eabi gcc-avr libalgorithm-diff-perl
  libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot
  libffi-dev libftdi1 libgcc-10-dev libhidapi-libusb0 libncurses-dev
  libnewlib-arm-none-eabi libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
  libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 libusb-1.0-0-dev libusb-1.0-doc
  libusb-dev make python2 python2-dev python2-minimal python2.7 python2.7-dev
  python2.7-minimal python3-appdirs python3-distlib python3-filelock
  python3-importlib-metadata python3-more-itertools python3-virtualenv python3-zipp
  stm32flash virtualenv
0 upgraded, 56 newly installed, 0 to remove and 12 not upgraded.
Need to get 245 MB/247 MB of archives.
After this operation, 2154 MB of additional disk space will be used.
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2.7 armhf 2.7.18-8 [311 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libpython2-stdlib armhf 2.7.18-3 [21.2 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2 armhf 2.7.18-3 [24.5 kB]
Get:1 http://mirrors.eze.sysarmy.com/raspbian/raspbian bullseye/main armhf libpython2.7-stdlib armhf 2.7.18-8 [1802 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libusb-0.1-4 armhf 2:0.1.12-32 [21.6 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libftdi1 armhf 0.20-4 [17.0 kB]
Get:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libhidapi-libusb0 armhf 0.10.1+dfsg-1 [13.0 kB]
Err:1 http://mirrors.eze.sysarmy.com/raspbian/raspbian bullseye/main armhf libpython2.7-stdlib armhf 2.7.18-8
  Connection timed out [IP: 200.9.157.182 80]
Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-avr armhf 2.26.20160125+Atmel3.6.2-2 [1049 kB]
Err:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-avr armhf 2.26.20160125+Atmel3.6.2-2
  Error reading from server. Remote end closed connection [IP: 200.9.157.182 80]
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-avr armhf 1:5.4.0+Atmel3.6.2-1 [12.4 MB]
Err:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-avr armhf 1:5.4.0+Atmel3.6.2-1
Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avr-libc all 1:2.0.0+Atmel3.6.2-1.1 [4878 kB]
6% [7 avr-libc 4076 kB/4878 kB 84%]
  • I have installed ubuntu server and Klipper on a PC without problems a few days ago, so I don't think it's a problem with my internet, the problem appears when I want to install it through Repetier Server
  • Yes, if that is where it aborts that is the issue. With unstable connection to pi the interface can freeze and the longer it take the more likely it can get. Longest is installing all the packacges missing. So what you can try is connecting via ssh to pi and run
    sudo apt install dpkg-dev fakeroot g++-10 gcc gcc-10 libalgorithm-diff-perl libalgorithm-diff-xs-perl  libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot libftdi1 libgcc-10-dev  libhidapi-libusb0 libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7  libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libstdc++-10-dev  libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 make python2 python2-minimal  python2.7 python2.7-dev python2.7-minimal python3-appdirs python3-distlib  python3-filelock python3-importlib-metadata python3-more-itertools python3-virtualenv  python3-zipp
    so when you run install next time these are already there reducing time. You can also rerun it if it fails.
    In Server you can after first configuration always rund uninstall and install to redo installation when selecting the Klipper tab. No need to redo image.
    Thank you so much. Install the packages with the command you gave me and reinstall Klipper and it worked!
    Now I have another question, I can't connect my Klipper printer to Repetier.
    I know that the printer has the firmware correctly installed and that the printer.cfg file is correctly configured because I installed Linux on an old PC, installed Klipper, I made the firmware of my printer and I was able to make it work (with monrake and mainsail)
    Now try to configure it, copy the .cfg (change the port since it was not the same) but it can't connect... I don't know what I'm doing wrong, any suggestions?
    Again thank you very much for the help
  • Just to be sure - you set in server the port to klipper socket and not the usb port, right. Because sever connects to klipper and slipper has as serial the port of the board.
    If that is correct you should see green connection link. When klipper does not connect to printer board or has issues with it you should see a warning icon on the link icon and when you click on it, it shows what error message klipper had send. If config worked and serial is correct you should also ensure both mainsail and server had installed same klipper version since they need a printer stub with functions as expected to their version. In server you can select 0.10, 0.11 and latest git which changes constantly. If in doubt run the stub generation in server and download and install it. Then version matches for sure.
    probably that's where my mistake is, I used the same port in the Klipper and Server configuration. Now I don't know how to do it correctly.... What is the socket klipper port? The port I use in RepetierServer and in the Klipper configuration looks something like /dev/serial/by-path/....
    From your answer I'm sure it's wrong, but I don't know how to do it correctly. I just reread the Repetier manual but I couldn't solve my question... I don't know if I'm looking at the correct documentation
  • I just saw that in the printer configuration, in the "Connection" tab, I have a port that says /var/lib/klipper/sockets/Klipper1
    There you should choose that port and in the Klipper printer.cfg you should put the port /dev/serial/by-path.....
    Is this how I should configure it?
    (I don't test it because I'm not at home and I'm watching it remotely)
  • That sound correct. Path is
    /var/lib/klipper/sockets/<printerSlug>
    but I also see the issue that it does not appear in port list. Will add that folder as well or even remove real serial ports for klipper. Might make things easier.
  • It worked! thank you so much
