Can't get Repetier +Cura to generate supports properly
I can slice in cura engine and I see ALL supports, but when I slice via Cura in Repetier, ONLY bed supports get generated. Why is this not using the same settings I have in cura?
  • Cura is a much newer fucntion I guess then what we use which uses the old configuration method and own configuration files. But that is not the reason. In Host you must set on the right side Support Type to Everywhere and not Touching Bed.
